theromstat
Discussion in 'The Garage' started by 1979jimmy350, Apr 11, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    what would give me better gas milage a high or low tempature theromstat?
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    on a carb'd engine, i doubt you will see a difference.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I always used to run a 180 t-stat with the carb'd deal, keeps the engine warm enough, yet stays cool enough too. Never had a problem with it.
    On the TBI i always run the 195, i tried to run a lower one and the engine/computer didn't like it.
    Yet on the TPI 350 i had in my IROC, i ran the 180 to try to keep the engine cooler, trying to get alittle bit more performance out of along with a lower temp fan switch.
    I personally wouldn't run anything lower than the 180 though.
  4. dyeager535
    26,982
    191
    Probably about the same.
    Fluids are thinner and easier to pump at higher temperatures (less drag on the oil pump for instance) yet higher intake charge temps hurt power production. The 15-25* change in engine temp probably means little to the intake air charge though, but you'd have to have some pretty specialized equipment to really figure all of this out.
