these fumes are killing me...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by amm888, Sep 11, 2002.
  1. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    hey guys, i need some help cuz i can barely stand to drive my truck anymore... /forums/images/icons/frown.gif
    i've got major fumes, and just now i noticed that it ain't just exhaust fumes - it was smelling like pure gasoline in my truck. i can smell the gas smell quite strong around the rear outside and inside the truck.
    any advice? has this happened to anyone?
    thanks a lot,
    alex
  2. dyeager535
    26,979
    I had a problem with the carb's float level once, and it was spewing gas into the air cleaner, which made a pretty strong smell.
    Your just going to have to check all the fuel lines, tank and the carb to see where the smell is coming from.
  3. amm888
    Jul 20, 2002
    309
    Woodland Hills, CA
    the smell is strongest around the filler side of the gas tank. i did just fill the truck up a few days ago, but the fumes are there even when it's pretty empty (though maybe not as strong).
  4. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    There are rubber hoses -- at least my '74 and '77 have them -- from the filler pipe to the gas tank, and they leak pretty bad on my '74. It's how I know it's full; there's a puddle of gas on the ground underneath...
    -- A
  5. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    just stick a lit Zippo in the areas you suspect /forums/images/icons/grin.gif
  6. amm888
    Jul 20, 2002
    309
    Woodland Hills, CA
    i'm not seeing any leakage though...? but it stinks so bad i literally can't drive it anymore (luckily, i got a trusty ole' camry (4x4 12" lift, of course /forums/images/icons/grin.gif )).
    i guess i'll have to take the gas tank out and look at the connections?
    any other suggestions?? (besides the zippo idea (i'll try that tomorrow, when it's light outside))
  7. dremu
    Feb 27, 2000
    15,954
    445
    You better be kidding about the Camry.
    Taking the gas tank off seems like a buttload of work. I'd roll under the passenger rear side and look up there, see if the rubber's rotted.
    And look up front round the fuel pump. You've got the mechanical pump up on the front, passenger side of the motor.
    -- A
