These valve springs for my heads?
Discussion in 'The Garage' started by sled_dog, Mar 14, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
  2. dyeager535
    26,975
    Can't view that auction from where I am. :(
    Best bet IMO is to work with whoever made your cam, and who will supply your springs, to come up with the right ones.
    I'm sure flat tappets are the same as rollers in that regard, although perhaps a bit less "picky"...the cam manufacturer recommended springs based on the cam grind for me.
  3. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah no reason to mess around with cheap stuff, I'll just call Comp. Mine is roller as well, there is some considerations with that and valve springs too.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Roller cams require stiffer springs. The ramps are much more agressive and require special springs to prevent valve float.
    As stated before, get a matched package with your camshaft.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I usely go with Comp Cams. I like to get the "K" kits.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    wow just looked up the K kit for the cam I was thinking about. $975! What does it include???
  7. dyeager535
    26,975
    K kit parts list
    I'm guessing a LOT of things you don't need/would end up overpaying for, when all you want are springs.
    I guarantee as long as that kit includes roller lifters, a large portion of the price you quoted is going to be for replacement lifters.
    Thats one of the great things about roller cams...you can reuse your stock lifters.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    As I understand it, factory roller lifters are superior to all aftermarket options.
  9. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i use these springs in all the heads ive had rebuilt. work great and cheap. the local machine shop sells them to me for $16 a set. i wouldn't use them for a roller cam though.
