Thick 4x4 housing
Discussion in 'The Garage' started by Blazerteam, May 7, 2005.
  1. Blazerteam
    Blazerteam Newbie
    Apr 9, 2005
    Mo i rana .Norway
    Was just wondering about the differences between the housing for the th400 and th700 4x4 versus 4x2?
    Arent the material thicker on the 4x4 housing?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yes they are different. 4x4's tend to have K case transmissions. I don't think all 4x4 cases are K cases but alot of them are.
    Harley
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the main difference is that the 4x4 cases have the holes to mount the cast torque converter cover.
  4. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    It's more of a late vs early model thing rather than 2wd vs 4wd. From around '79 on most (if not all) trans shells were cast with the bosses for the HD flywheel cover. 2wd stuff was still equipped with the tin cover inspite of the fact they had the undrilled bosses for the thicker HD aluminum covers. All of the 4wd applications came with the HD cover.
    Take some time to familiarize yourself with the actual shells rather than applications. Go to the Webshots link in my sig and look in the parts album for example pics of an undrilled 2wd case.
