thick gears?
Discussion in 'The Garage' started by nicotine, Apr 2, 2004.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    if i have a numericly lower carrier than the gears i need can i use thick gears? please explain /forums/images/graemlins/ears.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    so you have (example on 14bff) 4.56 carrer and want 4.10 gears?
    thick gears are to fit 4.65 gears on a 4.10 carrier
    its not possible, let me tell you why
    the pinion is bigger on the 4.10s vs. the 4.56 so the ring gear mounting point is moved back away from the pinion. to make what you want work you would have to machine the back of the gears, thus weaking the ring gear as its too thin than designed. you may even go far enough to get into the valley of the gear which is junk.
    hope this helps
  3. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I think that's what he wants to do, TJ. He said the carrier is numerically lower than the gears i.e. 4.56 gears on 4.10 carrier.
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sorry my brain is working backwards /forums/images/graemlins/doah.gif
  5. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I know that feeling /forums/images/graemlins/thumb.gif
