Thick or thin gears?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pomai, Feb 15, 2005.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    I have a 14 blt ff, 4.10 gears with an oper carrier from a 1980 chevy 1 ton truck that I will be installing into my 88 Blazer. I want to install 4.56 gears. How can I tell if I need thick or thin gears. Thanks Ed
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well according to this , you need a new carrier for 4.56 , so I say you need thick gears to use your carrier .
    14-7/8 x 13"
    14 HOLES
    Irregular Gasket Pattern
    SPECIFICATIONS
    • RG Diameter 10.5"
    • 12 9/16 X 18" RH Threaded Bolts
    • PINION Diameter 1.75", 30 Spline CASE: 4.10 & Numerically Lower, 4.56 & Numerically Higher
      8620 Material Heat-Treated
      Assembly Specifications:
    • Cover Bolt Ft. Lbs. 20
    • Pinion Brg. Preload In. Lbs 20-25
    • Pinion Brg. Preload In. Lbs 10-15 Used
    • Ring Gear Backlash .005-.009
    • Ring Gear Bolt to case Ft. Lbs. 105
    • Side Brg. Caps Ft. Lbs. 100
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    thick gears. DOn't bother looking for a new carrier. Thick gears are easier to find than thin so the best 14 bolt combo is 4.10 down carrier with thick gears.
  4. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Not to mention thick gears are usually cheaper than the thin ones.
