Things to do when you have 8" of lift?
Discussion in 'The Garage' started by 84gmcjimmy, Mar 4, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Things to do when you have 8\" of lift?
    Hey, Im going to be getting a 8" lift when the funds are here, and I was wondering what things I have to do for it, like for steering correction and all that. And <font color="red"> Please </font> tell me who makes them and where I can purchase/do these things. Thanks /forums/images/graemlins/waytogo.gif
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    Re: Things to do when you have 8\" of lift?
    If you're NOT planning on doing crossover steering, get everything from Skyjacker as they have all the right pieces for steering correction along with longer brakelines. /forums/images/graemlins/waytogo.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Do yourself a favor, just stick with 4" or 6" and avoid the steering and driveline issues that 8" brings up.
    Front driveshafts HATE lifts over 6". Hell mine hates the 7" I've got.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    sorry, but whats cross-over steering? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Why do they hate lifts over 6"? /forums/images/graemlins/confused.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Angles.
  7. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay, but how do people with larger lifts than 8" deal with the vibration from bad angles? Isn't there some way to fix it? Thanks for the replies though /forums/images/graemlins/smile.gif
  8. MR4WD
    MR4WD 1/2 ton status
    Jul 28, 2002
    133
    Fort McMurray, Alberta.
    Or you could just man up and buy some real drivelines. I have had over 15" of lift in my trucks and ran front driveshafts at highway speeds. Shop for those at high angle driveline.
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Do they make driveshafts for 8" lifts? Or do you have to get them to make them custom according to your drivetrain? Thanks.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, you're right, that is always an option, one which I'm going to probably do eventually.
    With 1/2 or 3/4 ton axles though I see no need for 8" of lift. That's enough to clear plenty of tire, which will absolutely destroy any 10 bolt or D44 front with nearly any wheeling.
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    When I get the suspension to 8" of lift, I will have D60 and 14bff. /forums/images/graemlins/peace.gif
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    So will they? (Sorry If im inpatient /forums/images/graemlins/blush.gif ) Thanks for the help /forums/images/graemlins/waytogo.gif
  13. 84K5BD
    84K5BD 1/2 ton status
    May 19, 2001
    302
    arlington, mass
    i have an 8 in. lift. i'm using skyjacker softrides for springs . steering unless you don't really wheel it do a crossover, you can get away with a drop draglink and steering block but the minute you start flexing it out on the trails you'll lose steering input. mine is from ord. the front shaft will be your last hurdle, get a good quality one, i got mine from tom woods it has a 35 degree c.v it has been in for over 1.5 years with no problems.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Just wondering why 8" lift ??? What do you plan on doing with your truck ??? I've got 6" lift and it's questionable if I want to play on the rocks. Good thing rocks arn't my thing. With 6" my center of gravity is pretty high. Getting off at angles is kinda scarry, feels like it could tip over pretty easy. /forums/images/graemlins/deal.gif
  15. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    HAD shafts rock, I run them. I still dont recommend any more than 6" of lift though. Unless you plan on specializing in VERY deep mud and want to run 44" or larger tires, I dont think tall lifts are good for much in a practical sense.
    At any rate, driveshafts from HAD are built custom to your specs/requirements... so when you call you'll need the measurements from axle yoke/flange to t-case yoke/flange.
    What tire size do you plan on running? which axles? what gears? what t-case? more info would help us help you...
    j
  16. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ]Yes, you have to have custom shafts built specificaly for your vehicle. For the rear I would get a CV style joint for the top and a regular 1350 joint at the bottom with say a 4" tube. With the front you will need an aftermarket high angle CV and you might need to remove some material from the crossmember to make it fit. This may sound crazy for a sec but you may not need to actually lengthen your front shaft. From what I have heard a D60 pinion sits 5" further back towards the t-case because of the bigger housing, with an 8" lift that would be like having a 3" lift on your front shaft and should be OK. But I would say you might as well spend the money and upgrade your front to 1350 also why your at it.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    All axles put the pinion in the same location. The shaft isn't different because of the '60.
    In fact, the '60 in itself adds lift, so it effectively shortens your shaft.
  18. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    j
    I plan on running 38's, with D60 and GM14bff, NP205 t-case, 5.13 gears, and I want to run 8" for clearence for the tires and ground clearence with the axles, should I just go 6" if 8" is too tipping? I will be trimming fenders. Thanks for the replies, keep 'em coming /forums/images/graemlins/waytogo.gif
  19. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    j
    [/ QUOTE ] If you're not afraid to trim the fenders, go with a 4" lift to keep your center of gravity lower. 6" will work though. /forums/images/graemlins/deal.gif
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    For 38s I wouldn't try doing it with less than 6".
