think i am about to lose my clutch
Discussion in 'The Garage' started by 84CUCV, Apr 23, 2007.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Well, it comes out just about all the way before it goes. was not like that before. if its on the way out what should i put in? thanks
  2. W7NB
    W7NB 1/2 ton status
    Nov 9, 2006
    716
    Springtucky, OR
    Any shudder or slip? I don't remember if an 86 had mechanical or hydraulic linkage, but you may want to check adjustment.
  3. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    No slip. its was doing some wierd stuff about three hours ago. its a hydro clutch.
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    Check the adjustment first. I have had my adjuster nut come loose before and cause a similar issue (mine's mechanical, but the problem would be the same).
    It could be the clutch or throwout bearing going out though, too.
  5. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK looks like i am heading to a new clutch and bearing. Witch one should i go with? thanks
  6. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    hydro setups cant take a 3 finger style i found this out the hard way. :doah:
  7. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    yeah 3 finger ones sucks, get a diafram one
  8. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    i have no idea. what??
  9. sweetk30
    Nov 1, 2004
    25,544
    539
  10. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks
  11. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    now there is some shutter. what do you think of centerforce. for a ne clutch? thanks
  12. 1977k5
    May 26, 2003
    9,994
    130
    I have a Centerforce II and love it :D
  13. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Where did you get yours? i was going to go to jegs. what it set you back?
  14. 1977k5
    May 26, 2003
    9,994
    130
    I got mine from a local shop that is priced the same as Jegs. I think it was ~$300 for everything.
  15. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK thanks sounds good. anything else i should do why i am in there?
  16. 1977k5
    May 26, 2003
    9,994
    130
    I replaced the input seal on the transmission so that it wouldn't leak and ruin the clutch.
  17. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    OK got it thanks
