Think I found a "J code" intake
Discussion in '1982-Present GM Diesel' started by 6.2Blazer, May 19, 2003.
  1. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    Think I found a \"J code\" intake
    Snooping around a local junkyard and found a 6.2 equipped van with the intake and pump missing.......anyway, saw an intake laying in the back and I think it's a J-code intake. There was no EGR in the middle of the intake and it appeared to have split opening.
    Did the van version 6.2's have anything different about them?
    Does this sound like something that I should get?
    If so, what is a reasonable offer?
  2. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    Re: Think I found a \"J code\" intake
    sounds like a J to me. Throw 40 bucks at him...that's a deal. Diesel Depot wanted 80 IIRC. I'm picking one up for 50 in the near future.
  3. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    just curious. is it really worth the effort to change intakes for the amount of power gain (unless you already have it off)? it looks like a PITA to pull that intake.
  4. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Its real easy to pull, not sure if its worth it though cause I noticed no diffference.
  5. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I don't know if there is much gain just by adding the intake by itself, but when combined with other improvements such as either a tweaked pump or even a turbo it should help.
    The ol' Blazer will be do for a new pump and injectors soon so I figured it would be a good time throw on the intake then.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Actually it would make more difference if you get it with the matching heads.
    The J code engine other than the lack of EGR, had different heads, and those combined with the intake net you the difference in power.
  7. Tybee
    Mar 25, 2001
    1,565
    Centennial, CO
    [/ QUOTE ] Are you sure? I had both engines and im pritty sure the had the same casting #s. I could be wrong though /forums/images/graemlins/tongue.gif
  8. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I have one of each so I will let you know when I start tearing into them to rebuild.
    Maybe in the next couple of months.
    /forums/images/graemlins/thumb.gif
