think I got a problem
Discussion in 'The Garage' started by LittlecountryK15, Apr 11, 2005.
  1. LittlecountryK15
    LittlecountryK15 Registered Member
    Mar 30, 2005
    28
    Greenville,SC
    in my front axel there is fluid running out of the end on the drivers side...I would guess its a blown gasket but I really have no idea.
    any ideas
  2. ssls6
    ssls6 Registered Member
    Jan 5, 2005
    86
    Dallas, TX
    There are axle seals in the differential housing. It sounds like one is blown. The R&R procedure requires removing the axle, pulling the gear carrier, driving out the old seal, and putting in the new seal. This is a good time to do both seals, bearings, etc. You don't need to remove the knuckles unless you want to replace your ball joints.
  3. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    i'll second that :thumb:
  4. LittlecountryK15
    Mar 30, 2005
    28
    Greenville,SC
    thanks.....do you know about how much that will cost
  5. Grim-Reaper
    7,385
    Atlanta
    About $500 if you totaly go through it and replace al lthe seals (including at the wheels) ball joints and tie rods. Thats parts. The seals that are leaking are about $20 BUT you have to take all the other stuff apart to get to them. Might as well get it ready for the next 150,000 miles.
    Labor I have no idea.
  6. LittlecountryK15
    Mar 30, 2005
    28
    Greenville,SC
    man that really sucks.....I got alot of other stuff that I need to be doing but this is going to have to come first I guess.....thanks again guys for all the help
  7. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,030
    858
    Pinckney, MI
    Yeah my drivers side started leaking after my last wheeling trip. I need to take care of it but I'm saving for 4.88's And I'll take care of it then.
