think i may have f@#*ed up my deck
Discussion in 'The Garage' started by rwright07, Feb 1, 2006.
  1. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    so i was fooling around w/ the wiring from my kenwood deck to get the left front to work better, i put everything in last weekend n i was gettin sum bugs out.
    then when i go to turn it on n put a cd in, it wont read em... so i try like 3 others, same result.
    it makes the noise like its taking the cd in, but it doesnt stop, then it spits it back out
    what did i do???
    n more importantly how do i fix it?
  2. Brians89K5
    Brians89K5 1/2 ton status
    Jan 4, 2006
    535
    Rialto Ca.
    I had this happen once with a deck in a car when I was working os a stereo installer. The deck thought it already had a cd in it. What I had to do is reset the deck. I believe kenwoods may have a small fuse in the back, pluck it out, count to 10 then stick it back in. It should reset it self that way. If the fuse is inline on the hot wire, pluck it ouf of your constant wire, count to 10 then try it. In the case that there is no wire, just un-hook your battery! lol G'luck!
    ~Brian
  3. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    I've had it happen a few times to Kenwood decks. The reset thing always worked. You'll probably need your pass code (usually 4 digits) if you've set the security. Good luck with it. I'm really not a fan of Kenwoods, but they sound great.
  4. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Most Kenwoods have a small indented reset button on the front panel. Push it in with the end of a pin for 10 seconds:laugh:
  5. rwright07
    Jul 30, 2005
    536
    corporate hobo
    yea i went out after i posted it n figured if i disconnected the battery that it would do sumthing liek that
    n it worked
    what is this about a security code
    whenver the deck turns on it says sercurity code off
  6. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    You can activate the security code feature in the menus settings and when the unit looses power you have to enter the digit code to get it to turn on. I do not recomend it as most people only have it cause problems when they forget the code. Plus a thef doesn't know it is active till they have already stolen the cd player and by then you are already out of luck.
