Think I might have a rearend problem
Discussion in 'The Garage' started by PROFESSORSK5, Dec 20, 2003.
  1. PROFESSORSK5
    PROFESSORSK5 Registered Member
    Dec 19, 2001
    81
    So California
    When I try to start off too quick sometimes I feel a slip like the transmission is slipping, but it seems to be coming from the the rear of the truck. Has anybody else had this problem? Is it possible that the positraction could be slipping? /forums/images/graemlins/k5.gif
  2. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    What kind of positraction is it? If its factory its impossible unless the carrier is broken, but if the carrier is broken the axles would fall out.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    for like a split second or for longer ? humm.. higer rev right then and then slows up, or ?
  4. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Sounds like transmission to me.
  5. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    sounds like whta mine did when the tranny went out (broke the sun spool in it, which caused the shaking like breaking traction)
    700R4 by any chance???
  6. PROFESSORSK5
    Dec 19, 2001
    81
    So California
    It's a stock positraction. I had an aluminum dif cover put on and when they took the stock cover off two of the carrier bolts were broken, the guy just replaced the bolts. Its been a couple of years now. What I can't understand is that it feels like its coming fron the rear of the truck. /forums/images/graemlins/k5.gif
  7. PROFESSORSK5
    Dec 19, 2001
    81
    So California
    It feels more like a bad or slipping clutch in a stick shift truck. And the problen is it is random, it only happens once in a while. /forums/images/graemlins/k5.gif
