think I screwed up
Discussion in 'The Garage' started by ssped, Sep 2, 2006.
  1. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    I ran down to the Junk yard and grabbed a 8lug set of rotors backing plates and spindles. The Hubs were not locking like the ones I have on the 10b but are just a solid plated bolted on like a rear FF14b axle. I imagine it was all wheel drive. Can I just go get a different hub (isnt what the rotor and studs mounted on called a Hub too)?
  2. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Possibly, what application are you talking about?
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Yes, the rotor hub is called a hub too, and yes, the locking hubs just unbolt.
    Presuming you got rotors, spindles and plates from an otherwise identical truck (i.e. they're all Chevy, D44 or 10-bolt) you can mix and match parts ... I used my old locking hubs (Warns) from my six-lug set up on my 8-lug 10-bolt, and it all fit.
    The full-time things are called drive slugs, and yeah, they just un-bolt and the hubs go in like they do on your existing axle.
    -- A
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    you just have to be careful if u picked up the earlier d44 hubs/rotor...they are expernal style hubs and will not work with the newer internal style ('79+) 10b/d44s
  5. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    they would work if you also picked up the spindles, but you would also be running the smaller bearings
  6. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    heres pix
    I am puting it on a 82 10b front end. I took the spindles backing plates rotors hubs... everything but the calipers so I knwo it will all swap over. the question is on the end cap/plate. the 10b has external locking hubs and the pieces I pulled have these plates. can I get just the Hub that the rotor mounts to? the locking hubs I have I dont think they mount to these hubs.
  7. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yep thats the external style wheel hub assembly. you wont be able to use your other locking hubs
  8. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    are there locking hubs for these? or can I get another style hub from a part store cheep?
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    they sell them. warn makes a set. look on 4wheelparts.com under d44.
  10. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
  11. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    thats not Bad. 100$ for the good ones. the truck is going in on tuesday for them to fix the rear pinion so I will pick up a set. Thanks. that works good.
  12. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    got a set here at the house i'll give you for $45 and shipping
  13. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I'd get the set that use the splined type locking hubs. The bolt-on hubs are PITA to keep tight.
  14. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    Send me a pick of the ones you have. Are they the better Warn ones?
  15. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    got her DID!
    I grabbed all new bearings and races and went and installed all the parts. I found out the 10b and 8lug 44 pieces are almost all the same. same bearings, spindles... the rotors were hitting the backing plate/spindle mounting bolts when I installed them and I had to take the grinder to them to make them work. I also picked up a premium set of warn gubs to complete the setup. it came out really nice and was really really easy to do the swap over. I am just waiting for my matching wheels to get here and I will get up some pix.
  16. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    They are only a PITA to keep tight if you use the bolts and locking tab washers. When I installed mine, I went and bought a bunch of studs, washers and nuts and have never had one come loose.
  17. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    I will keep and eye on them. I will try thread locker and hardened bolts if they come loose at all. one of the holes in the rotor is trashed and I will need to drill and tap it. I will do that soon. ran out of time yesterday.
    Thanks fer the tip.
  18. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    MISF (that is: "My Infamous Scout Friend") tried everything. First G8 bolts, then alloy SHCS, then studs. Didn't matter, they all gave up. The studs lasted the longest, but that was only a couple months.
