Think my tranny's screwed up
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by deek, Jun 23, 2003.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    Think my tranny\'s screwed up
    with the shifter all the way up, I can still roll my blazer down the driveway. would it be that the linkage is outta wack?
  2. dyeager535
    26,979
    Re: Think my tranny\'s screwed up
    Probably just the linkage. If you crawl under the truck, you can disconnect the shift linkage, and manually work the bracket on the side of the tranny. Each gear should give you a solid sound as it detents into each gear. Once you get it all the way into park, you can check and see if that fixed the problem.
    IIRC, there is no way for park NOT to work short of external problems, unless the internal rod is ruined or not there somehow. The only internal piece I see being "prone" to failure is the spring on the park assembly and even if it failed, it would keep the tranny in park, not let it roll.
  3. DOCKAWI650
    DOCKAWI650 Registered Member
    Sep 29, 2002
    61
    Gboro, NC
    Could be the transmission...i had a similar problem with a old mercedes. put it in park and it would start rolling and you could hear the transmission pumping and the gears not catching. It could be the tranny or linkage...
    -Doc
  4. blasterD
    blasterD 1/2 ton status
    May 24, 2003
    410
    Anchorage Alaska
    I think you probably just need to adjust the linkage. Have you been wheeling lately and twisted up the frame? Put some chocks under the tires and crawl under. See if you can disconnect the linkage and put it in park by hand. If this doesn't work you may have some serious tranny issues.
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If it's not external, it could be the park pin.
    It's a very whimppy pin, I don't know how they trust this pin to hold the truck but it works if you don't jam it into park while you are roling stil.
