Think this would be a good spot
Discussion in 'Audio' started by Z3PR, Jan 18, 2006.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    too mount my CD Changer ?? [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Just too tight under the passenger seat, the right rear corner of the trunk looks like a good spot. I can get to the magizine too change discs when need too, and will be easy too mount. No worries about wires or gas/break lines under there.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Can you set the suspension so you can vertically mount it there ? Looks kinda cool that way .
    Another spot that woudl look cool is under the package tray over the subbox , if your mounting brackets could be flipped so it hangs down .
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I was going too mount it between the 6X9's, but these those rods running from side too side in the way. It can be mounted either vertically, horizontally, or at a 45 degree angle. I kind of like it where it's at in the pics. It's out of the way. (Note; will run cable under carpet / trunk liner when mounted)
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Ended up mounting it vertically too take up as little room as possible. Tucked into the corner as far back as I could get it. I'll take some pics in the morning, too dark right now. Ran the CeNET cable behind the carpet/trunk liner.
  6. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    So long as mounting it that close to the sub doesn't cause any skipping issues, I dont see aany problem with mounting it there (or where you describe vertically now). Keep up the good work.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I was pounding it pretty hard this morning, and not a single skip.
