Thinkin about getting a new K&N
Discussion in 'The Garage' started by George_Pimpdaddy, Mar 18, 2007.
  1. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    So i have a regular round k&n on my 89 tbi blazer now and need to replace it after over 2 years of good service and have seen the FIPK kits for newer tbi's and wonder if it could be used on my 89 k5. Heres the listing for the package im talkin about http://knfilters.com/search/product.aspx?Prod=57-3026 just looked up 95 suburban 5.7.
    Anyways i was thinkin this setup might be better than what im running now and also help clean up the look. thanks for any input guys :wink1:
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Waste of money. Your stock CAI setup with a K&N already flows more air than your TBI truck needs.
    Why do you need to replace your K&N that you have? Just clean it.
  3. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    I tried a FIPK on my 96 7.4....wasn't impressed for the 30hp claimed. I returned it. I got an Airhog element for my 95 5.7, removed the vacuum door and the heat riser, then ran a piece of aluminum expandable ductwork to the fender opening, and it was enough to feel it in the pedal.
  4. George_Pimpdaddy
    Oct 17, 2002
    1,306
    its getting a little damaged from wear and tear its over 2 years old and i dont have the cai tube any more either so im jsut running with the flipped lid
  5. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I tried this in the Burb once, drove it around the block, and said SCREW THIS, i hooked the CAI RIGHT the frack back up. Too much hot air for it, especially here in Arizona,,,nasty
    Sure you get an interesting sound from it, but wow did it NOT like that setup, lost power bigtime.
  6. 70GMC
    70GMC Registered Member
    Nov 1, 2006
    40
    Reno, NV
    don't k&n filters carry a million mile warranty?
  7. rolereversal
    rolereversal 1/2 ton status
    Jan 28, 2006
    115
    Los Lunas N.M.
  8. Thunder
    Jul 20, 2000
    8,946
    Northeast Nevada
    Well you need to get cold air to your throttle body. TBI dosn't like hot under hood air and you acually loose power runing a open element air filter. So either go with the aftermarket CAI if you can find one. Or Get the stock CAI and aircleaner housing. from a junkyard.
    I dont know who makes a CAI kit for a Blazer. I dont think the one you show from K&N will fit a Blazer. If you look at the vehicle applications they dont list Blazer and dont list Suburban untill 1992, when they made the change form SFA to IFS. Dont get one for a K Truck they have totally diferent CA intake system that hooks up to a hole in the fender well. Blazers CAI run up to the front into an air box
  9. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    did you send in your warranty form that came with the filter? i forgot to. you konw how it is. set something aside and don't find it again for 3 years or something. but now, i really wish i'd sent it in. my filter shrank and won't fit properly under the lid. my friend had the same issue with a k&n and something else (don't remember what). similar construction. still works, it's just goofy.
  10. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    goto the junkyard and offer 4 or 5 bucks for the cold air intake hose+ core support attachment part.. Might want to think about taking the airbox too if it isnt like your current one.
  11. George_Pimpdaddy
    Oct 17, 2002
    1,306
    i used to have the hose part but the hedder ate it lol so looks like ill just get the hose again
