thinkin about sellin 33s for some 35s * NEED PICS
Discussion in 'The Garage' started by NEK5, Apr 9, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok got a quick question, my buddy grabbed a lift kit for his 90 blazer so i was thinking about selling him my 33s and he`s gonna give me a set of rims i like and i was thinkin about trying to get some 35s....so my question is will i be fine running 35s or will trimming be neccesary??it hasnt seen any offroading yet but will see a little soon....also any one have any pics to compare 4 inch with 33s and with 35s?
    TIA
  2. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    come on guys....any recomendations and/or pictures?
  3. bangedup
    bangedup Registered Member
    May 17, 2003
    21
    Alberta
    yep,trim it up or use a BFH that'll get'r
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    i know it my be hard to say but where would it be necessary if it would, to trim?
  5. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    do you guys think i should even bother trying to run 35s?....one reason i want is because if i sell them to my buddy he`s gonna give me a set of rims he has that i really really want
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I swear this question is covered twice a week:mad:
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hey i`m sorry man....i think i might stick with the 33s but get different ones...that way i can get his rims and some bfg muds
  9. 88trailblazer
    88trailblazer 1/2 ton status
    Apr 11, 2004
    425
    Miami, Florida
    here is a pic of my old 88 with 4in and 35x12.5R15s. I didn't trim anything with 4in lift but I did crush in th back of the front fenders a little. nothing that was too noticable. You should be fine for some light offroading.
  10. Janitorjim8
    Janitorjim8 1/2 ton status
    Feb 21, 2005
    215
    Illinois
    Depending on how much you flex it out, 35s will fit fine without trimming, or just a bfh on the back of the front fender
  11. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    what gears are you running with your current 33s? if its anything higher (numerically lower) than a 3.73, you should really consider regearing. your trans WILL NOT like you with short gearing.
  13. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    how do i find out?
  14. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    anymore?
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    pull a cover, and count the teeth on the gears. divide the number of teeth on the ring gear by the teeth on the pinion gear.
  16. NoReGrEtS
    Nov 7, 2005
    848
    I wonder how my times that has been said
  17. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Honestly, this has been covered 1 million times before. Same exact question. Use the "search" feature, it is your friend. To answer your question, 35's should fit with 4" of lift no problem. If you go wheeling somewhat, it will probably hit when flexing. I run 37's on about 6" of lift, and it fit without cutting. Thing is, it would rub pulling into my driveway. I had to cut a lot to run them with no swaybar, and some pretty hard rock wheeling. If you need to cut them after you go wheeling, youll know how much. Just flex it out till it rubs, then get out and mark what needs to be cut. Very simple. Mine rubbed so bad with no swaybar all the way flexed out, that i though i was either gonna bust a new mtr, or the motor stall. :eek1: :eek1:
    -Harrison
  18. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    you can also just mark the tire. then mark the driveshaft at the diff yoke. count how many times the driveshaft goes around in order to make the tire do one full revolution.
    i cant even tell the difference in a 33" and 35" by looking. they are both small tires once you've seen something over 40" wheel. and BTW, ive seen 35's on a 78 with no lift.
  19. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    35s and no lift= fender trimming
    my 77 is stock factory original chassis and it has 33 x 12.50 onit and i had to trim the fenders because they will rub just on the street when you turn too fast
    so,,,
    but then width affects this too
    id like to find some better 33" tires
    mine are just about garbage, old and dried up and real bad curb rash on a rear one and the other day i rashed a front one on a damn curb along the main drag, so.,.
    damn curbs!
    too bad i wasnt in MA to buy them off ya,
    i would..
    good luck
  20. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    thats just so wrong lol
    barf
