Thinking about cable clutch????
Discussion in 'The Garage' started by Batmanjr, Oct 12, 2002.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Has anyone made a Cable clutch? I'm thinking about making my clutch work from a cable with ballbearing ends! The throw on the 465/4500 is only 3-4" and I could easily attach the cable inside the cab to the pedal! It wouldn't be hard to make a bracket to hold the cable on the transmission! Would it work? Or would the force needed for the clutch be too much???? Any opinions???
  2. Grim-Reaper
    7,385
    Atlanta
    Hydrolic would be easier. use a pull style slave. Make a mounting point that replaces the access cover on the side of the tranny as a mounting point. Here is the set up on a SM420
  3. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Grim,
    How is that attached to the clutch fork? Would make it easier for me than changing bell housings
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I still say that looks like junk.
    the double nut grinding away at some plate, and I can just imagine the fork end is equally as ugly.
    it could be done much nicer then that but as the factory has already done the work it is so much easier to use off the shelf parts
  5. swamp donkey
    swamp donkey 1/2 ton status
    Apr 29, 2002
    186
    Thousand Oaks, CA
    I REALLY want to replace my mechanical clutch with hydraulic. I have read all the posts, and I kinda get what needs to be done. However I have more money than time (and not much of either). Any ideas what kind of shop would have the knowledge to do a conversion like this?
