Thinking about parting out my 1987 Chevy CC on 52" Michelins and Rockwells
Discussion in 'Complete Vehicles' started by OffRoader93, Sep 14, 2005.
  1. OffRoader93
    OffRoader93 1/2 ton status
    Nov 30, 2002
    262
    Engine: Rebuilt 6.2 Chevrolet Turbo Diesel. New main and rod bearings. New rings. Cylinders were honed. Lapped the valves. All new seals and gaskets. Has rebuilt injectors from Diesel Injection Service of Illinois. New fuel lift pump. New oil pump. Has new glow plugs. The best part is the Gale Banks Sidewinder Turbo Kit. Custom turbo that livens the engine up quite a bit. Motor runs strong. Has a Caterpillar smoke stack right off the turbo through the hood. Has a K&N air filter with inlet coming out the hood. Doesn't have 10 hours on the engine. The estimated horsepower is about 200 and the torque is about 400. This engine has nice low end power.
    Tranmission: Has the Turbo 400 that came in it. I had to put a diesel torque converter in it. This has a lower stall. Have an external seal kit, but never was put in. The seal kit will go with truck. Seems to shift fine. Doesn't seem to slip.
    Transfer Case: Has the NP 205 gear driven case that came in it. Everything seems to be fine with the transfer case. Hard to break these cases. Have seal and gasket kit for transfer case I never put in. The kit will go with truck.
    Axles: Rebuilt 2.5 ton Rockwells by USA 6x6. These axles have 6.72 gears. USA 6x6 went through these axles and replaced any bearings or seals that were bad. I had them install Detroit Lockers in both front and back axles. I had them also intsall Wilwood Pinion brakes on both front and back axles. These are some beefy axles. Have Earl's Braided Stainless Steel brakelins run from the hardline to the pinion brakes. The steering on the front axle is full hydraulic. I put a new hydraulic pump on the motor to power the steering. Has Orbital Valve to control flow of fluid to make the tires turn. Has a aluminum reservoir to hold the extra fluid.
    Tires and Wheels: The tires are 52" Michelins military tires. They are awesome tires. Have lots of tread left. These are thick tires. They probably weight 300 lbs a piece without wheels. The wheels are military wheels put on backwards. This gives the truck a wider stance for better stability.
    Suspension: This is a one ton suspension. It has a SuperLift 16" suspension lift. Have all four shocks. I did not mount them because it is not necessary.
    Other parts: Have a heavy duty front winch bumper that is not mounted. I have a Boost guage, EGT guage, Oil Pressure guage, and Water Temperature guage mounted on the dash. The boost and EGT guages are Banks and the oil and water guages are Autometer. Has a piece of c-channel for a back bumper with a Caterpillar tow hook in the center and a smaller hook on each side. Two homebuilt traction bars on rear. One homebuilt traction bard on the front. They hold the axle in place, believe me.
    If there is any part you are interested in, just PM me. Thanks.
  2. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    don't spose yer gonna post pics and prices are ye? :D
  3. Michk5
    Michk5 1/2 ton status
    Jul 19, 2002
    139
    Misawa Japan until December...moving to Wichita Ka
    Here is a pic he posted earlier!!! I sent a PM concerning a few things earlier today...but prices would be great :D
  4. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Shoot me some details on the orbital valve and the reservoir... Prices would be nice too.
  5. OffRoader93
    Nov 30, 2002
    262
    Will separate any of the parts. Thanks.
  6. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    too bad i am going back to school in january. I really want a turbo diesel to put in my 89 scotsdale cc dually :D
  7. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    so the 6.2 is running the stock pistons at 21.5:1?
  8. OffRoader93
    Nov 30, 2002
    262
    Not sure about the compression.
