Thinking of doing the unthinkable... *Rotor to cap gap. Normal?*
Discussion in 'The Garage' started by y5mgisi, Jan 26, 2007.
  1. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    I am at my wits end with my surging at idle issue on my 90 and cannot think of anything else to try. I think i have to take it to a mechanic:( . I just feel totaly lost and helpless. ive done everything i can think of and nothing helps. Today i had the injectors rebuilt becasue in my mind i knew that that was the problem for sure! but i put it all back together and guess what? no change... I just dont know what to do. I can rebuild a motor and an automatic transmision but i cant solve a stupid idle issue on the most simple of fuel injection systems. I am just going to feel like so much less of a man handing the keys over to someone else becasue I cant fix the problem...:frown1: :dunno:
  2. jk5blazer
    jk5blazer 1/2 ton status
    Jan 28, 2005
    306
    Braselton, Ga
    what do ya mean surge... does it act like you have a cam. Might be a vacum leak. Mine would surge at idle like that and was running real rich. It was the O2 sensor. Hope you figure the problem out!
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    Yep, give us more details on what you have done, and how it is acting. One of us may have dealt with a similar problem at some point :)
  4. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    plug up every vacuum port on your engine, start it and see how it acts (dont drive) if no problem there then start hooking up one vacuum line at a time and look for changes etc. etc. if there is an initial problem start tightening every single nut and bolt on your intake and throttle body and then move on from there.......worked for me I found the vacuum leak the mechanics could not find.
  5. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    can try brake clean or carb cleaner to find a vac leak as well
  6. southern customs k5
    southern customs k5 Newbie
    Sep 9, 2006
    4
    georgia
    egr valve stuck open
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Sounds like one I had once, it was a map sensor of maf sensor or whatever ya call that thing.
  8. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    used starting fluid to find an intake leak once.
  9. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    That' my bet too. I had the EXACT same problem as you w/ my '87 burb. It happened TWICE in less than a year :mad: . Talk about irritating. Do yourself a favor, if it is your EGR, buy an OEM unit. The ones from the parts store are junk. It's worth the extra 10 bucks for a good one.
  10. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Ok dudes. I just rebuilt the motor. It runs perfect as long as its not idleing. and runs the same iwth the egr hooked up or capped off. uive done the carb clean thing to check for leaks and coame up with nothing.all the vacume lines on it are new cause the old ones where crap. When i put the motor back in i replaced the o2 just cause i thought it would be a good idea and the knock sensor because i couldent get the old one out of the block without destroying it. sence then(this is going to sound stupid and it is) ive replaced the map, TPS, had the injector pod rebuilt, and put a 195 t-stat back in(was runing a 180) I even got the thing to pass DEQ.
    The problem is this. Your cruising around and you come to a stop light. It runs perfect for about 30-45seconds then it starts to run rough about 5 seconds then sonds like its going to die then idles way back up to about 1500 rpm or so and it does that over and over again. You can make it stop by taping the gas pedal real quick but then again it will run fine 30-45 seconds and start the cycle all over again. but like i said it runs great as long as its not idleing.
  11. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    ive seen explorers do that with bad fuel pump relays...
  12. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You may want to take a real close look at the dizzy. On my 90 Burb, it was coming apart under the little metal shield. Don't know what its called, but I knew that cracks in it were bad. It would run ok under load, but it wouldn't idle for squat. I put the trail spare for the blaze in it and it was fine.
  13. Steve GMC
    Steve GMC 1/2 ton status
    Dec 3, 2005
    247
    middletown,Connecticut
    same thing happened to our coevette. it was the computer. it would runl ike garbage cold, then when it warmed up it would run better if it wasnt idleing
  14. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    man... i just went out and checked the codes and all i get is code 32 EGR but that is becasue i was driving it with it capped off. Does anyone know of a way to test the computer? and i'll pul the cap and rotor off the dist. and see if anything looks a miss.
  15. JpEater
    JpEater 1/2 ton status
    Nov 20, 2005
    299
    Augusta, Georgia
    Capping off the EGR wont do any good if its stuck open. Sounds like it could be stuck open causing a vacum leak that you can't find with carb cleaner. Pull it off and check it out.
  16. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    ok, what exactly would i be looking for to give me a sign that it was stuck open?
  17. WRENCH-HEAD
    WRENCH-HEAD 1/2 ton status
    Dec 25, 2005
    327
    Littleton, CO
    I've been battling the same problem for a year now. Just started one day and I have yet to figure it out. I'm down to thinking a vacuum leak. If I disconnect the MAP sensor it runs perfect. The techs told me this was because the map sensor is what know if you have a vacuum leak and trys to compensate. So I guess try pulling the vacuum line the MAP sensor and see what happens.
    -Alex
  18. lrazer
    lrazer 1/2 ton status
    Oct 3, 2004
    231
    Mokena, IL
    u check the IAC?
  19. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    yea, the Iac can cause it to hunt, try cleaning it out, or getting a new one. also, you need to remove the egr and make a blockoff plate to check it.
  20. mike n
    mike n 1/2 ton status
    Oct 9, 2003
    101
    New York
    What's the TPS reading at idle?
