Thinking of going back to rubber bushings...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Apr 4, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I have a TC 3" lift that came with poly bushings i nthe front springs. So far I have taken them off twice to grease the bushings, they were squeaking really bad. I greased them really well too. Now they are making the front susp. bind sort of...i can feel them acting wierd when going over big bumps...do I need to use marine grease to do this? If I use marine grease will I still have to grease them? I guess I could get ORD's greaseable bolts...
    90K5
  2. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Mine squeak also. Haven't noticed any performance issues. Going to run em until they bust!
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    You might try loosening up the bolts on the springs and put some lock tight on the end so the nut doesn't back off, then go hit some bumps.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    If your suspension is binding I would say your bolts are too tight, or they weren't torqued while weight of truck was on them. Make sure were the bushing goes it is smooth, no rust or paint, then grease, and grease metal sleeveand bolt this will keep it from rusting together.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I would have guessed they were too tight too, but I know I torqued them to specs. Plus I looked down there the other day, and the front ones were backed out about 1/2"...I torqued them again.
    90K5
