Thinking of going with a higher lift
Discussion in 'The Garage' started by Chrisblazzer89, May 5, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok so as some might know I have an 88 :k5: with 3/4 ton axles with 4.10s and a 4" lift on 38.5 TSLs. The thing is Im getting a lil boared with the 4" lift and im thinking of going 6"- 7" of lift.
    What will I need to get 6"-7" of lift with some flex?
    Pic of my truck
  2. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    flip out back, zero rates and a 1" body..
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    you going up to 44's or something? LOL
    nevermind you have 4" ruffies. get some 52's up front with some fabbed brackets or Kerts kit and be set.
  4. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    :wink1::wink1::D:D;);)
  5. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I have thought about a body lift But I rather not go there.
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    What are 4" ruffies?
  7. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    rough countries one of the stiffest springs out there, limited flex and rough riding
  8. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Man do you have that right!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  9. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Thats why im asking because i want to use my current springs
    Would a 2" flip and removing a leaf help?
  10. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    1" body lift and new bushings is an awesome mod... no drawbacks and plenty of advantage..
    3", not so much..
  11. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I would have to do modding to the shifter linkage.
    I cant weld!! I would otherwise
  12. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    up front-shackles,and a zero rate should give you right around 6 to 6 1/2..
    out back-shackle flip,zero rate and a set of 7 inch shackles...thats my current setup...
  13. BGKYK5
    BGKYK5 3/4 ton status GMOTM Winner
    Nov 1, 2006
    5,936
    on the crapper...
    Completely off topic, but Chrisblazzer89 how do you like the tire and axle ratio combo? If all goes well, I'll have similar tires, but I can't decide what ratio to run.
  14. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Ok so I'll be the first to ask...why?
    You've got 38.5's clearing on 4" of lift...why not cut the fenders a little and put that money into something useful...like gears (I run 4.10's and 38.5's as well and its not low enough), new tires (those tsl's are looking a little bald), a locker, performance parts, iono...something...just seems like that money could be put to better use since you are already clearing them perfectly fine.
  15. Blazn83
    Blazn83 Registered Member
    Dec 11, 2006
    54
    Mechanicsville VA
    yeah, how much have you already trimmed to fit 38.5's with a 4" lift?
  16. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    X2!
  17. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    x3!
  18. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Yea I was thinking about the same thing last night and I think I will just save for a detroit for the rear and a dana 60 for the front and new tires will come soon:D
    BTW Im probly going to just get some zero rates for all 4 corners
  19. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I have 4.10s and its fine but the low first gear in my 700r4 helps. But I say got 4.56s or aslong as you dont do high way go 4.88s or higher.
    Im going 4.88s or 5.13s
  20. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I run 38.5's with 4.10's and a brand new 2nd gen 700r4 and although it feels low enough coming from much higher gearing trust me when I say its not low enough :)
    Your tranny will thank you for dropping gears.
