Thinking of lifting the rear end of my 91 k5 an inch?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Piranha300, Feb 24, 2002.
  1. Piranha300
    Piranha300 Registered Member
    Jul 1, 2001
    45
    Nebraska
    It has the illusion of sagging in the rear because of the wheel wells in the back not as big as the front. Anyone else do this to their Blazer?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, I just did that. I used the ORD 1" add a leaf. It worked well, and I am very happy with the stance with the add a leaf. I am also very happy with the product. It improved the look and stance of my truck alot. I highly recommend it. The only side effect I have had is driveline vibs, but I also have 2-2.5 inches of lift in the rear prior to the addaleaf. When i get home during spring break, I will drop the tcase a little, and I should be fine. If your truck sags in the back the ORD addaleaf is a great cure.
    My Chevy isn't broken, its just out of gas.
  3. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I would use ORD's 0 rate add a leaf, theyre only $40 I think and install is a breeze.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
