Thinking of welding the spider gears up front
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by xnoahx, Aug 10, 2001.
  1. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    Would this be a really bad idea, i know that it would always be a full locked axle but if i just keep the hubs in the free lock then i shouldnt have any problems, right?? I do have a part time kit in my 203 so thats not an issue.
    Check out my 73 K5 <a target="_blank" href=http://members.theglobe.com/xnoahx/73k5.htm>http://members.theglobe.com/xnoahx/73k5.htm</a>
  2. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    From what I understand of spools, I think this would be a really bad idea. On a turn, the outer wheel turns more and faster than the inner tire. Since the steering is up front, this is highly exaggerated for the front wheels. Meaning, in a curve the outer front wheel turns quite a bit more compared to the inner wheel than is true for the rear axle. If you weld the front, I think you would have serious chirping or break and axle/gear.
    But I could easily be wrong. I am just picturing the track my wheels (all 4) take when I go through water and then turn. I am picturing the track marks left on the ground. The inner rear wheel go the least distance followed by the outside rear then the inside front and the outside front goes the farthest.
    Brian
    Click to see <a target="_blank" href=http://tx85gmcguy.alloffroad.com> My 85 Jimmy </a>
    PM me for a great deal on blinker fluid! Best price on the net!
  3. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    Yeah, you are right about the inside wheel and the outside wheel rotating at different speeds in turns but what i am wondering is would it be all right whem my locking hubs are "free." I raised the front end of my truck off the ground a while ago and and turned the yoke on the diff and both wheels only turned when the hubs were locked.
  4. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    I Have A Detroit Locker In The Front Of Mine.I Can Run With No Problems As Long As I Keep The Hubs Unlocked. With Them Locked I Cannot Turn Well On Pavement . I Have To Make Very Wide Turns Sometimes Even Off Road When The Hubs Are Locked .
    A Big Hammer Can Fix Anything ..
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's why I don't have a front locker and I don't want one.
    Tim
  6. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Yes, once your hubs are unlocked it won't make a difference (ie on the street).
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  7. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    The other post-ers are coorect, but "personnally" I think you asking for trouble.
    Does anyone have a grinding disk I can borrow?[​IMG]3/4 in progress[​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  8. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    A detroit locker or any other no slip locker is going to handle the same as welding the spider gears or puting in a spool then i say save your $400 - $500 and weld it up use the money you saved and get some chromoly shafts extra u-joints and a twin stick shifter so you can disengage the front to make those tight turns.
    [​IMG] [​IMG] [​IMG]
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Or just leave it open and avoid the hassle, breakage, and steering problems (and give up some traction). It just doesn't make sense to me. Everyone says that only locked 10 bolts and Dana 44s break when locked. I can tell you for a fact that both are EXTREMELY strong, no matter what tires you have on them, when the're open. I've never seen any small block powered vehicle break one. But obviously you can do whatever you want.
    Tim
  10. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I second that 84, at the most I'd put in a limited slip.
  11. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    10s are not strong in the rocks---thats what I do---i need the extra traction, but cant afford a 60,,,so im gonna spool the front 10, get some extra shafts and take it easy--- mud and rocks are COMPLETLY different forums of wheeling---mud you need a healthy engine w/ HP and hit the gas and go...rocks---you dont need a "healthy" engine--you need torque, you can have a 6 banger in a k5, sm465 and low gears and a good driver and follow Mr. Watson--when diong the rocks there is going to be a point where only one tire is gripping and we all know what happens when you're open--but when you locked that one tire is going to get you out..you dont get to pick which tire is going to get the grip all the time so lock the front and back and its a wham bam thank you mam and your out
    Hut in the well is goin on in here?
    sun desert offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
  12. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    With a 10B it almost makes more sense to weld it up. If you don't like the way it handels then just go get another carrier. Even if you have regeared it doesn't matter because they use the same one from 2.73-4.88, and since its just the front axle the gear set up doesn't need to be perfect, ie a great time to learn. If you do it I would strongly suggest doing a cross over steering. Twin stick &amp; upgraded shafts would be nice, too.
    Jim '80 GMC & '73 Blazer
    Tread Lightly!
    <a target="_blank" href=http://www.gmck5.rockcrawler.com>www.gmck5.rockcrawler.com</a>
  13. xnoahx
    Oct 12, 2000
    817
    Ventura, CA 93004
    and i have a D44, not a 10B
  14. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    Right, but you have a mini-spool, too. Same idea, if you don't like it you can "restore it to normal"
    Crap, that was another thread, sorry! What I meant to say was you could get a mini-spool. Uh-yeah.
    Jim '80 GMC &amp; '73 Blazer
    Tread Lightly!
    &lt;a target="_blank" href=http://www.gmck5.rockcrawler.com&gt;www.gmck5.rockcrawler.com&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by bigjbear on 08/12/01 12:32 AM.</FONT></P>
