This axle in my truck?
Discussion in 'The Garage' started by Wally81k5, Jan 5, 2003.
  1. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    I recently found a 12 bolt in a junk pile. I was intrested because i have 3.08's. Soo can anyone tell me if i can pop this carrier into my housing to lower my gears. its a 12 bolt like mine, and is stamped 3817778 11-41 G.M. 60 i think it is 3.73. it came off an old like 50's truck but may not be the original for that truck. Also, how wide is the stock 12 bolt in a blazer? and where are you measuring from? Thanks for your help!
  2. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    [/ QUOTE ] Yes, It is a 3.73. The 11 is the number of teeth on the pinion gear and the 41 is the number of teeth on the ring gear. /forums/images/graemlins/usaflag.gif
  3. Wally81k5
    Jul 14, 2002
    139
    Cold Lake Alberta
    Cool 3.73 is okay for me.
    So does anyone know if this carrier will work? I found out its actually from a 72 chev. 2wd.
    Also still wondering about those measurements.
    thank guys!
  4. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I dont have measurements but last I looked into this swap just pull the 6 lug shafts on your axle and swap them into this scrap pile axle and call it good. you now have a 4wd 12bolt with the 6lug pattern.
