This is kind of a weird dana 44
Discussion in 'The Garage' started by TrcksR4ME, Apr 14, 2005.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I'm no expert, but that looks like a dana 60 to me. The studs and only one U-bolt on the passenger side is what makes me believe it is. Someone better snatch this one up!
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    Cant really tell from the pics other than the perch studs. But if it came out of a newer Dodge 3/4 ton, then it is a balljoint D60...
    But one thing has me puzzled. They were disconnect axles since thee were no lockouts. BUt this axle doesn't have the disconnect housing.
    Did the pre-94 Dodges have no hubs and no disconnect,, and a balljoint 60????
  4. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    It's a D44. I don't know why, but Dodge made some of their trucks with 44's having 2 studs on the passenger side leaf pad like a D60. That's why it doesnt have the center disco.
  5. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Dodge D44. Dodge uses studs in the pumpkins side on D44 and D60 just the same. It looks like a full time unit so not worth a whole lot since you will need x-over to shove it in a GM.
  6. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Dodges have a narrower spring pad width than Chevy, so they had to use the studs there. It is a 44.
