This is probably a more appropriate place for this question...
Discussion in 'The Garage' started by Capman2k, Dec 12, 2002.
  1. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    I posted this in my post in the off-topic forum about an 86 GMC Suburban at a local car lot...:
    ------BEGIN TRANSMISSION------
    Ergh...
    I went to look at the Suburban today... It looks extremely nice, a little hail damage and the passenger front seat was ripped a bit. Started it up and it started pretty well, could use a new starter... Let it warm up while I walked around and checked the underside... It sounded alright, little smoke from the tailpipe... Power stuff all worked... I got a license plate and stuck it on the tailgate and pulled out of the lot... Gas pedal was a little stiff, about the same as my Scout and my Jeep and probably my Blazer (but I don't remember)... SO I started truckin down the road and hit 30 mph and there was a loud annoying hum echoing through the inside... I rolled down the window and it sounded like it was just on the inside... I slowed down to turn a corner and it went away... Then I started speeding up again, and at 30 mph, the hum was back... It's hard to explain what it sounds like... I thought it might've been the tires, they look kinda loud... But it didn't sound like it was coming from the tires...
    SO I got it back to the lot and took the keys in... Didn't think to ask about the sound. The guy gave me my license and asked if I wanted to buy it, I said I'd think about it... He lowered the price to $1800, no trades. So I said I'd think it over and go back if I wanted it...
    Anyway, what might that loud annoying hum be just out of curiosity??? /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/burb.gif
  2. Grim-Reaper
    7,385
    Atlanta
    hard call. Could be resenece off the exhaust system...could be the rear end eating itself. Try to hold a lower gear and see if it still does it. If it still does it at the same speed then it's either transfer case, rear end or tires.
  3. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    Could it be a tire out of balance? Maybe a loose driveshaft?
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    could be a harmonic vibration in the driveshaft. i've heard of that happening before. i also know that if you remove the plastic from around newer model vehicle driveshafts, that they are really loud.
  5. Capman2k
    Jun 22, 2001
    5,070
    dg
    Thanks for the info, y'all... But I'm going to pass on the Suburban... I don't want to end up in a situation like I did with my Blazer where it was in the shop every other weekend costing me ANOTHER $200... can't afford that in money or time, so I'll just keep looking /forums/images/graemlins/smile.gif
