this is what happens. . . .(PIC)
Discussion in 'The Garage' started by aburnett, Jun 2, 2003.
  1. aburnett
    aburnett Registered Member
    Oct 25, 2002
    30
    Birmingham, AL
    ...when you dont tighten your pinion nut enough, setting your new preload and crush sleve(aka the bumping noise in reverse I mentioned in a previous post
    http://webpages.charter.net/aburnett3/MVC-002F.JPG
  2. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    OUCH!
  3. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    that sucks
  4. Grim-Reaper
    7,385
    Atlanta
    That's not good. /forums/images/graemlins/crazy.gif
  5. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    oops /forums/images/graemlins/blush.gif
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I can't see the pic from work due to the firewall but I am assumeing that is is a busted R&P. If it is how long until it busted, milage wise.?
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    tear in my eye /forums/images/graemlins/frown.gif
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Ouch! That's a pretty expensive lesson in what NOT to do. /forums/images/graemlins/wink.gif /forums/images/graemlins/frown.gif
  9. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Ummm, gouges are baaad, Mmmkaayy /forums/images/graemlins/eek.gif </font>
  10. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif Sorry for the loss!
    -Harrison
  11. aburnett
    Oct 25, 2002
    30
    Birmingham, AL
    actually, I think im ok.
    The ponion looks fine(pic if u want one).
    http://webpages.charter.net/aburnett3/MVC-001F.JPG
    I only went maybe 20 feet in reverse about abour 5 mph. I was very carefull testing it first thing and the second i heard the sound I just backed on into the garage.
    I found a place wehere I can rent a inch-pound wrench so I can set it properly tommorow.
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Silly question, but how did you manage to properly set up the gears with the pinion banging around like that? /forums/images/graemlins/confused.gif </font>
  13. aburnett
    Oct 25, 2002
    30
    Birmingham, AL
  14. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yup, you did some mighty fine pooch-screwing there, but at lest you caught it real fast. /forums/images/graemlins/thumb.gif </font>
  15. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/shocked.gifouch, not good
  16. aburnett
    Oct 25, 2002
    30
    Birmingham, AL
    Re: this is what happens. . . .(PIC) (updated)
    On the road again!
    Man torqing the nut down was unreal /forums/images/graemlins/shocked.gif. I Talked my wife into using the floor jack on the cheaterbar I was using while I kept the socket from twisting off. All of that to turn it an additional 1/4 turn needed to get my 12-14 inch pounds of preload.
    Anyway I am mobile again. I do have a "surging" vibration at hiway speeds that I now need to rectify. (I mainly think it is the back output on the t-case. This summer for my B-day Ill get a MM part-time kit and kill two birds with one stone.
  17. Grim-Reaper
    7,385
    Atlanta
    On the road again!
    [/ QUOTE ]\
    Both my 203 trucks have what sounds to be the same searge. The one did it when it was still full time, did it with the mm 501, still does it with the MM shaft kit. Not noticable till up around 60mph more noticable a 75mph. Seems to have stayed the same the whole time I have owned the truck. The 203 reduction box I believe is straight cut gears and I think that's the issue.
  18. aburnett
    Oct 25, 2002
    30
    Birmingham, AL
    It only started doing that surge and the past few years. Ill pull my front shaft and check all the U and CV joints.
    My front shaft has unbelievable slack in it. Id like to be able to do some descent Interstate driving in the future, so I'll try to track that down.
    Any unbelievable PITA's when install the shaft kit? Other than poor instructions that I've read here say come with it. It seems blissfuly more easy than redoing the crush sleave and preload /forums/images/graemlins/rolleyes.gif
    Im not familar with a reduction box ill have to read up on that. any more info on that would be most appreciated. BTW thanks for earlier posts to get me over my mental block /forums/images/graemlins/wink.gif
  19. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Whoops... /forums/images/graemlins/frown.gif
  20. Grim-Reaper
    7,385
    Atlanta
    Shaft kit is easier to install then the 501 as long as you have a new pump gear for the shaft. The GM part number is included in the instructions. The shaft kit is great.
