This might be a stupid question, but....
Discussion in '1982-Present GM Diesel' started by chevblazk5, Mar 8, 2004.
  1. chevblazk5
    chevblazk5 1/2 ton status Premium Member
    Mar 19, 2002
    257
    Sayreville, NJ
    How hard would it be to swap a 6.5 diesel into a 1990 Suburban with 6.2 diesel? As far as I know the 6.5 is mechanically injected.
  2. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    The 6.2L and 6.5L blocks are virtually identical on the exterior, meaning it would be a direct drop-in bolt-in deal. If you've found a used 6.5L turbo diesel, then the turbo assembly will hit the a/c box in the older style truck. If it's an n/a 6.5L, then it will bolt right up with no problems whatsoever.
    It would be just like swapping a 6.2L for another 6.2L.
    Casey
