this motor any good?
Discussion in 'The Garage' started by PsychoticDeadGuy, Oct 13, 2005.
  1. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    I found this motor...clicky...is it something that is good? i only have about $2500 dollars to spend. so after shipping and the engine...i will have the money to do a little bit to the K5...
    edit: go to first post on pg. 2
  2. PsychoticDeadGuy
    Jan 8, 2005
    753
  3. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    looks to be a good engine for the price and it has a warranty.check with a gm dealer and you might get it even cheaper.
  4. 1-ton
    Apr 17, 2004
    2,890
    168
    Las Vegas, Nevada
    As long as you do not have smog requirments to pass, then you should be good to go. The engine you are looking at is just a little pumped up (about 30 HP over stock), and is going to be right on the edge of passing smog inspection.
  5. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
  6. PsychoticDeadGuy
    Jan 8, 2005
    753
    why would hp have anything to do with smog inspection...as long as i have my catalytic converter on then it should be good. right? i am in cali if that helps.
  7. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    if its a fresh motor and all the smog stuff is hooked up i dont think you will have any problems with smog if you are unsure just run the higher octane gas before the smog test that tends to help. as far as horsepower that shouldnt effect it that much unless you have a wild cam or something.
  8. 1-ton
    Apr 17, 2004
    2,890
    168
    Las Vegas, Nevada
    California are the ultimate smog Nazi's. HP has a lot to do with passing the emission tail pipe sniffer. More HP = more fuel being compressed into the cylinders, which = more Hydrocarbons.
  9. PsychoticDeadGuy
    Jan 8, 2005
    753
    then why could my GF's dad get his camaro to pass smog when he is pushing over 500hp? its a 2000 i believe....
  10. 1-ton
    Apr 17, 2004
    2,890
    168
    Las Vegas, Nevada
    I dunno? Ask him...maybe he will be able to help with your truck, if you have a problem :D.
  11. PsychoticDeadGuy
    Jan 8, 2005
    753
  12. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    I don't know if it matters or not but i think the blocks are the same as far as the way they bolt up.... if you are using fuel injection i think there may be a difference but then again there may not be waiting for someone to chime in to find the answer to this question.
    I was told a long time ago that you can put injection on an older carbed motor but im not sure what to do other than change the manifold and make sure that all the locations for the sensors are there so that the computer can function properly
  13. PsychoticDeadGuy
    Jan 8, 2005
    753
    i was going to put my intake on it...i know all the SBC intake manifolds will bolt up between the early 60s or so up to about the early 90s or late 80s...as far as i have been told.
  14. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    what kind of injection is it?
  15. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    I got my new 350 Small Block for about $1,000 and it's relatively the same numbers for horsepower and torque. I would say look around some more, other people will have some good deals. :D
  16. PsychoticDeadGuy
    Jan 8, 2005
    753
    i have TBI. i will order an edelbrock intake manifold if i get the engine but the TBI unit will stay the same...maybe new injectors or something...but will be TBI
  17. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    ok i found out that everything should be ok as long as you have all the TBI and sensor parts from your old motor to put on the older block if anyone thinks otherwise let us know
  18. PsychoticDeadGuy
    Jan 8, 2005
    753
    thanks...i will look into it a little further and i will call the company tomorrow.
  19. bridgeguy
    bridgeguy Registered Member
    Mar 8, 2002
    90
    Oroville, Kalifornia
    If memory serves: in Kalifornia, if you replace an engine with a different engine, the law requires you to conform to the more stringent requirements between the vehicle and the powerplant. E.g., if you put a new Vortec pick-up engine in an 85 Blazer, you will be held accountable to conform with the Vortec requirements. If you put an 85 Blazer engine in a 77 Blazer, you would have to conform with the 85 Blazer emissions equipment and standards.
    The only exceptions I know of are that, currently, 1975 and earlier vehicles are smog-exempt. This means that you can do basically anything and not have to sweat it.
    But, if you are running something newer, you are going to have problems. If they are in a really picky mood, they can run the block casting and/or displacement and you can get tagged on that if they decide that you are trying to bypass the regulations.
    I haven't kept 100% up to date on the requirements as I started either buying new vehicles and not screwing around with them, or buying older smog-exempt vehicles.
    As for your girlfriend's father's Camaro pushing 500 hp smog legally: there are a LOT of ways to increase the output on the F-bodies with the newer small blocks. These parts will have a CARB exemption number which means that the Kalifornia Air Resources Board has finally gathered that the replacement part does not contribute to increased emissions when used as the manufactuer recommends. At least that is the short version or what I understand about it.
    Kalifornia IS the smog-nazi and trying to understand why they do things or to attempt to apply logic to their rulings will do nothing but drive you insane.
    Good luck on your engine hunt. Personally, I'm a fan of the Goodwrench engines. When I worked for Chevrolet parts (12-15 years ago), if your Goodwrench that you installed had a problem, they handled all the labor and parts under the warranty. Even if you installed it yourself.
  20. PsychoticDeadGuy
    Jan 8, 2005
    753
    ok, thanks for the insight. i will call the DMV tonight and see what they say...hey, your in oroville? im heading out there this weekend. i wont have my k5 with me though.
