This problem is blowing my mind???????*******UPDATE********
Discussion in 'The Garage' started by TxK5Blazer, Aug 31, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    I had problems with my truck last night I put in a tach and it must have grouned out somehow and the truck died last night no spark disconnected the tach this am and she started right up. COOL right , not. I then went to get gas for a road trip on this extened weekend and she died at the gas station...bummer got pulled the the house about 3 blocks away let her sit for a while and with some hesitation she started right up. Well I know its not the coil but made me think could be the module going bad I noticed it was running rough and would back fire through the carb meaning the timing is off right ? So I just happened to have a new module here at the house and put it in well cleared up the problem with the starting and running rough well I took her on a test drive and she is still backfiring into the carb. I have check the wires and the plugs and the timing all good funny thing is she backfires on the road but wont do it in the driveway. When I accelerate on the road she backfires and not when I accerlerate here in the drive way. WTF could be wrong I am stumped.....Jason
    *****UPDATE*******
    I took her to the shop today and found out my coil was burning up had burned up the cap and rotor and the pickup was shot. that all got fixed but still backfiring through the carb the did a compression test all cylinders reading good but the #3 one was at 50 psi and they think it is in the valve somewhere not seating or the valve spring or something they are going to tear it apart tommmorow and find out thanks for all your help guys That alone is worth the membership
  2. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    Re: This problem is blowing my mind???????
    TTT come on guys 18 views and nobody has any Idea my brain is fried thinking about it.....
  3. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Have you checked the timing with a light? also, check to make sure your getting enough fuel at the carb, might be a lean condition, that could be why it only backfires on the road when its eating a lot of gas. It you have a holley take out the screw on the side of the boal and make sure its up to the hole with fuel.
  4. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Forgot to mention, make sure your running on all cylinders as well by pulling plug wires one at a time with it running listening for rpm drop.
  5. TJS
    TJS 1/2 ton status
    Nov 13, 2001
    179
    Westport,CT
    Sounds like a bad pickup in the distributor if it is an HEI which I assume it is. This required disassembly of the dist. to replace the pick-up. Sometimes you can see the windings around the pick-up look brittle and deteriorated.
    T.J.
  6. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    i am with him i think its in your distributer check your contac points and the little springs for the counter balance weights are the srings there and are the weight's moving freely
    i have learned new does not allways mean its good
  7. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    How about the carb? Had this problem with mine recently and we rebuilt the carb, and changed the plugs and she runs like a champ now. Kit was like $25 at Oreily's. Was pretty nasty inside. Just a suggestion.
  8. Dandwg
    Dandwg 1/2 ton status
    Feb 9, 2003
    190
    Turlock, California
    Just wondering if any of the suggestions worked for future reference /forums/images/graemlins/smile.gif /forums/images/graemlins/k5.gif
  9. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    well guys I have tried every suggestions beside the pickup isn't that in the bottom of the distributor not real familar with that. The carb is only about 6months old and I dont' think that is the problem. I will take it to the shop tommorow and let them take the distributor apart and check it out.....Jason
  10. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    check the cap for a crack in it.
  11. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Have you been hard on the motor lately? If it turns out not to be the module or some other distributor problem you may want to hink about the timing chain. I think someone else mentioned checking you timing
    Just another thought
  12. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    ok this is a stupid question I started it this morning hard to start not like usual ok but then noticed a whinning type for noise coming from the water pump area could be the water pump or timing chain right or am I being stupid
  13. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    TTT
  14. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Hey, maybe my timing chain idea isn't so far off. How many miles are on it and has the timing chain or gears ever been changed??
  15. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I had some problems with my distributor awhile back, did a lot of the things yours is doing. I took it to a shop and they said it was the module, turned out it wasn't. I took apart the cap and coil and noticed the ground wite for the coil was corroded. I cleaned it up, put it back together, and it has worked ever since. That was 2 years ago.
  16. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    If i am not mistaken that is the orignal timing chain that I remember. about 4 years old and I think If the is is I should change the water pump at the same time right .....Jason
  17. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Water pump is easy..you have to take it off anyway but why replace it if it's not bad??
  18. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    how do you know it's not the coil? when my coil went a few years ago it didn't back fire but did run like s**t. a couple days later it just stopped running while iwas driving. or like a few people said it might be timing, i've revved it up enough to get the chain to jump a tooth or two. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
