this seams wierd, 83 s-10 with 2.8 and 5 speed 4x4... bone stock with 4.11?
Discussion in 'The Garage' started by 55Willy, Mar 26, 2007.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    the gears were marked 9:37 which would be 4.11 right?
    and the stamps didn't the pattern I have seen on others with the GM and the 7 or 8 digit code and then the pinion and ring gear stamp and the date code. this just had the GM and i think it was 8 digits and then the 9:37 on the end of it.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    9/37 = 4.11 that's for sure. Just to make sure count the teeth and do the math.
  3. dremu
    Feb 27, 2000
    15,952
    443
    East of San Francisco
    Scott would know better than I about motors and their power bands, but my Amigo, for instance, has a similar (3.2L) V6 and 4.10:1 gears stock... something about smaller motors needing more gearing, or maybe it depends on the torque curve? :dunno:
    -- A
  4. Stump-a-holic
    Stump-a-holic Registered Member
    Mar 21, 2006
    29
    South Wales, NY
    I pulled factory 4.11's and a gov' locker from an early model S-10 that had a 2.5 4 banger in it. Buddy used the body and frame to put on top of a K5 chasis, welded frame to frame and used on the road, very scary I know but we were much younger then. I snagged both the front and rear axles and put them under my long bed with a 4.3 and only 30" tires. With a shift kit that was a very very fun truck.
  5. dyeager535
    26,975
    Yep, 3.42's and 4.10's used to be the most common S10 ratio's out there. I had to search hard to find some 3.42's (kept finding 4.10's) for my friends S10 a few years back. I can't recall anymore, but the combination was something like small engine, manual trans=4.10's. Larger engine, auto trans, 3.42. His was a 4.3/700 combo.
  6. dbozman
    dbozman 1/2 ton status
    Nov 11, 2006
    115
    Phoenix
    Small motors tend to get deeper gears. Same deal with the 2.5L Wranglers; most had 4.10s.
    d
  7. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I'm looking for a set of 4.10s for the front of an S-10, and from what I've been reading 83 and 84 were the only years for them. When the 4.3 came out pretty much everything got 3.42s, and 3.08s for 2wd's.
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    4.3 didn't come out til the 87-88 year. so there should be more out there.
  9. Kp
    Kp 1/2 ton status
    Apr 5, 2006
    135
    Tucson
    My 86 trooper has 4:55's stock. 4:77's were an option on some models.
  10. REDCRO_REDNECK
    REDCRO_REDNECK 1/2 ton status
    Apr 7, 2005
    241
    mo
    there is a difference in the code for the gears between 410 and 411 the 411 specificaly was shown under the H** code410 were a g** code. learned that from 1987 s10 I owned for 2 years. my truck was also a 2.8l 5 speed 4x4 with all the skid plates and off road shocks. also has 235/75 15 tires not the 215/75 15 tires.
    typicaly the 411 was used in the more off road ready trucks.
    wonder if you have my old truck?
