This sounds BAD!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MadIrish, Aug 27, 2001.
  1. MadIrish
    MadIrish Registered Member
    Aug 13, 2001
    48
    South Carolina
    When I am driving, I get to about 10 mph and can hear a sound like popcorn popping in a metal skillit. It only happens when I am rolling and happens when I am both pushing the gas pedal an not. It sounds like snapping-metal creaking- poping all out badness. Seems to be coming from tranny-transfer case.
    I am wondering if my transfer case is out of tranny fluid. I have a leak coming from the back of the transmission. The 'rear seal'?
    I'm gonna try to top off the xcase tonight. Any other ideas? It sounds like I am killing the poor thing.
    I have an 82 K5, stock drivetrain. 350 4bbl and a NP208. Pretty sure it's a 208. Thanks a bunch!
    ps, not sure what tranny, basic K5 though. What will a tranny rebuild set me back?
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Could be a U-joint preparing to shuffle loose of it's mortal coil - there's been a rash of that around here lately[​IMG]. Also check all of your trans/t-case mounting.
    If the shoe fits, get another one just like it
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. MadIrish
    Aug 13, 2001
    48
    South Carolina
    U-joint. Hmm...... May be time to break out the Chilton. Never changed one before. Could be bad if the front one breaks eh? Turn the driveshaft into a pole vault.
  4. LittlePig
    LittlePig 1/2 ton status
    Aug 9, 2000
    299
    East Texas
    Rocks in the hubcaps? If you get over 10mph and it goes away, check to see if you got some gravel in the wheels. Once you get the wheels spinning fast enough, the gravel would be held in place by centrifugal force, and stop making noise, but below that it would be slow enough for them to get pulled around by gravity.
    Email: littlepig@keepandbeararms.com
    ICQ: 84108805
  5. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    U-joints are pretty easy to change - if they are still the factory joints, you'll most likely have to heat them with a torch to get them out. BTW - Need to get that profile filled out[​IMG]
    &lt;a target="_blank" href=http://pugsley.alloffroad.com&gt;pugsley.alloffroad.com&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by Pugsley on 08/27/01 03:53 PM.</FONT></P>
  6. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    MadIrish,
    Check the 4 bolts that bolt your T-case to the trany.
    Mine were loose to the point of almost comming out.
    I also had a bad experience of the Torc Converter(sp?)
    bolts comming loose and it sounded most likely what you have going on with yours.
    Let us know what comes from this,
    KEN
    DANGIT it's not a bronco!
  7. MadIrish
    Aug 13, 2001
    48
    South Carolina
    I'll do that.... tomorow.
    I was just under the truck and took the transfer case top bolt out, and BLA-FREAKIN-AM! A gusher! Does the tranny feed the tcase? I had a jeep and the 208 in it held it's own fluid. If I popped the top bolt on it, nothing would come out. Now I do this on my K5 and it freaking spews!!!!! What is with that?! I had to literaly take a shower in GoJo!
    82 K5 All stock but wheels and tires, 305 4bbl, tranny? NP208
  8. SWAMPRNR
    SWAMPRNR 1/2 ton status
    Apr 7, 2001
    296
    Temple Texas
    My 82 HAD a 350auto with a 208case and had its own fluid.
    I did blow some seals once letting fluid from the transmission get into the t-case somehow..that what the shop told me.
    A Big Hammer Can Fix Anything ..
  9. MadIrish
    Aug 13, 2001
    48
    South Carolina
    Im wondering if that is what is going on. Didnt make sense. How much did the work cost you?
    Any ideas what an auto tranny rebuild costs on the average?
    *******82 K5 All stock but wheels and tires, 305 4bbl, tranny? NP208*******
  10. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Could be a bad axle bearing in the rear axle. Are you leaking gear oil out an axle tube?
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  11. MadIrish
    Aug 13, 2001
    48
    South Carolina
    I havent looked. Is that the same thing as a breather tube on the diff? Im not sure what an axle tube is. I've only been in this particular truck for a month, before that it was mostly cars and the one 4by (Scout II) I sold before I monkeyed with it. So, any more info on that would be great!
    Ps, is an axle bearing the same as a wheel bearing? I imagine not.
  12. tRustyK5
    Jul 23, 2000
    36,179
    1,387
    E-town baby!
    There is a seal between the tranny and the T-case...the tranny will continue to over fill the T-case until you re-seal it. Until you can replace that seal watch you tranny fluid level and also the fluid level for the T-case.
    Rene
  13. MadIrish
    Aug 13, 2001
    48
    South Carolina
    Ah so! Will it hurt the tcase to be over filled?
