This trailer thing is starting to get on my nerves.
Discussion in 'The Lounge' started by Jagged, Mar 20, 2007.
  1. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    So I removed the broken leaf and the same leaf from the other side, got the hubs installed, locknuts tightened, cotter pins installed, bearing buddies installed, wheels put on.
    Then I took the trailer off jackstands...
    The side that had the broken leaf is reall unsprung. I have about 1" of clearance between the tire and the fender.
    :angry1:
    I've got three options right now:
    1)Try to find some 30.5"x1.75" springs
    2)Find a helper spring to install
    3)Ghetto-rig a bump-stop/lift block
    Any ideas?
  2. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I go with number 1. There's gotta be a place out in Mesa that'll sell trailer springs off the shelf or at the very least be able make some.
    Besides, the longer you stay in town the better chance we'll get to meet.
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Got any spring packs around with more arch? Slap a few leaves in there. If they're too long you can cut them down in the chop saw and radius the ends with a grinder.
  4. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I would look for a new spring. If there is a Tractor Supply Company in town, they might have the spring you need.
    Here's a link to the site.
    http://www.mytscstore.com/
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    As of last night , there is room for the tire now . Mitch put the leave back in , with a little zero rate type piece I had in the garage . Its bolted to the springpack with a brand new bolt , so its perfectly safe .
    Now he just needs a new U-joint on the Blazer , and he will make it home fine :thumb:
