This why you don't run a D44 with a Detroit and 36's, carnage pics inside
Discussion in 'The Garage' started by Okiemuddog, Jan 25, 2004.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    This why you don\'t run a D44 with a Detroit and 36\'s, carnage pics inside
    Well, had some friends in town, so we all load up in the blazer to do some lite wheeling, head to vacant acreage acros the street from my house. The road running in is pretty rough with some preety deep ruts, so for fun I drop the driverside tires into the rut and start up the hill. I get to the top of the rut and the is a little rock ledge that the runoff has exposed, I bump the front tire against it gas it a little to bump it over and the tires breaks loose, a little dirt over the hood and a boom in the front axle. I start trying to back out of the rut to look under the front end and I hear is the axle clunking arund in the knuckle. The U-joint blew two cross shafts off, tore the ear off the stub shaft, tweaked the other ans the ears on the inner shaft. I now have D60 on the way /forums/images/graemlins/thumb.gif
    Krennen
  2. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Re: This why you don\'t run a D44 with a Detroit and 36\'s, carnage pics insi
    Time to upgrade /forums/images/graemlins/thumb.gif
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Re: This why you don\'t run a D44 with a Detroit and 36\'s, carnage pics inside
    Ouch!! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    -Day-nauh-six-tiey-
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/pimp1.gif
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Damn...congrats. My two breakages were almost exactly the same this year.
    It sucks to hear that pop every time you have the wheel turned and hit it at all. It gets OLD!!
  6. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    2" 50 spline rockwells? /forums/images/graemlins/grin.gif
    j
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Did you expect any less?
    That is the reason mine is still open up front.
    How old was the u-joint in there?
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    nah, 406 Unimog axles /forums/images/graemlins/cool.gif
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    Pbbbbbllllllppppppptttt!!! Rockwell 5 ton! /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  10. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Yeah, Rockwells!!!!We know where we can get some cheap, huh? Knowing Krennan's luck, he'll find a dana 44 advertised for $200, and it'll turn out to be a 60 /forums/images/graemlins/1zhelp.gif
    John
  11. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Look close, that shaft almost took out the lower ball joint stud. The easiest way to avoid that is to find a mismarked kinkpin dana 44 (marked as a dana 60 to confuse the less able).
  12. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Sorry to see that breakage, might you try using a stronger U-Joint, like the Dana(Spicer) 5-297x or the newer replace
    ment(5-560x).
    200x3x2.6x4.1=6396lbs./ft.
    half to the front, half to the rear
    must have been one heck of a shock load !
  13. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Nah, Mogs break too easy /forums/images/graemlins/grin.gif
  14. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    [/ QUOTE ] Nope, did not get one for $200, had to pay $630+shipping from New Jersey /forums/images/graemlins/eek.gif for a DRW D60 and going to need a rebuild/calipers but already has 4.56's.
    Krennen
  15. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    OUCH /forums/images/graemlins/doah.gif
  16. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Who here has used full circle c-clips on there 1/2 ton shafts ? I just ground down all my shafts and my spares to take a full clip external snap ring. The caps walking out can cause the most damage, the fastest. If you can keep the ujoints in place, they are much more likely to hold together ! Use 1.25 inch snap rings.
    How old was that rusty joint anyway ?
    Blake
  17. Okiemuddog
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    The joint was about a year and a half old, looks like hell I know. My driveway turns into a mud pit everytime it rains just a little bit, so suspension is terminally rusty. /forums/images/graemlins/rolleyes.gif
  18. Grim-Reaper
    7,385
    Atlanta
    Hmmm 38 year old truck tthat has run 38's all it's life and been pounded on by litterally hundreds of enlistend men all over europe and carried god knows how many more tons then it was rated how many times then made into a rock crawler after 35 years in the service. ....yeah they break a lot! /forums/images/graemlins/rotfl.gif
    CTM's and Warns if your going stick with skinny sticks and not going any bigger then the m 36's. Sofar I have not managed bust mine with 35's an a lunch box locker.
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Blake
    I agree with you, but when you snap the cross in half, retention most likely wasn't the problem. You can weld your caps in if you want, the honest to God reality is that we're just beyond the design limitations of a stock U joint, and they break.
  20. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Actually, this should maybe be reworded as:
    "This is why you dont put too much power down when the tires are hard up against something immoveable and trying to turn with a D44 with a Detroit and 36s"? /forums/images/graemlins/smile.gif
    We have all been there... but as long as you learn from the carnage, you can still run D44s without excessive breakages. I broke one front u-joint in my D44, with my 4:56s, right after I put in the Trutrac, it of course took out the axle ears same as yours. I was jammed hard against the side of a rut as deep as my tire, trying to turn a bit to climb the edge, and slowly but steadily putting more and more power to it. She let go (not suprisingly!) but I learned what not to do, and havent broken one since... not saying I wont, but havent since hehe. Good luck with the one ton stuff, but for the newbies: you dont need to run out and buy D60s... you can wheel with 44s! /forums/images/graemlins/smile.gif
    Mike
