This with Hydro Steering...
Discussion in 'The Garage' started by sled_dog, Jan 4, 2006.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Are you happy with it? Would you go back to linkage steering? Have you had any issues with the engine dieing and no steering? If so, were you able to turn the wheels by hand with the ram in place?
    That is my biggest fear, can I keep the engine running well enough to not have that issue?
  2. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    I am going full hydro no matter what, whether I go full tube chassis or use a TJ as a base. I wonder how many horse you would need to spin the pump, maybe hook up a dc motor as a backup so you can still steer.:D Or maybe use your winch to pull the wheel to one side or the other.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you could always disconect the ram and turn the tires by hand... a PITA im sure, but its doable.
    Grant
  4. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I'm happy with mine. I can steer with the engine dead. It's not easy, but better than trying to turn the tires by hand. I have a full size Chevy steering wheel, so the diameter helps.
    The only thing I don't like about it is when certain events have rules against full hydro.
  5. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    is it just me or when i have to turn the steering wheel really hard i break rag joints? maybe im just too buff :doah:
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    That is why one need one of these.
    I got it from a late 80s XJ in the junkyard, walla no more rag joint.:D No cutting required both ends bolt right up.
    Ira
  7. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I drive Hyster @ work all the time, and all of ours are POS! And I can turn any of them with the engine off. It's just like manual steering, hard to turn if your'e not moving, but eazy if U are. They are all full hydro with dbbl. ended rams. U can use a good saginaw PS pump to run full hydro, I know because we have done it befor with Hysters that the pump has gone out on. (they use 1 pump for all the hyd. on the whole thing) It worked fine for just the steering, but I DON'T recomend trying to run the forks @ the same time:haha:
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah I was thinking about a DC backup pump. I think I will do it and if I find the steering to be an issue, install a DC pump.
  9. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    I have full hydro. Yes you can turn the wheels if the engine does die. It does take a little effort to turn them but it does turn.
    I like how I can turn my 39.5 Swampers with 5psi by using my pinky finger.
    My K5 is a trailer queen but if I do have to drive it on the street to me it sucks. My tires follow the groves in the road real bad so I steer left or right to compinsate(sp) next thing I know I have over compinsated.
    I hear people drive there rig on the street with full hydro ether there ram is a lot faster than mine or they have just got use to how it handles.
  10. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    I love full-hydro. It is by far the coolest thing I ever did to my rig. The only thing that took some getting use to, is not being able to "feel" your way around the trail through the steering wheel. The steering has sooo much power and the feedback is minimal in comparison. Precision driving took some practive afterwards :D
    You've already learned that you can still steer without it running. However, if your truck runs so badly that you're worried about it, you should be putting the money in to the motor, not steering :doah:
