thm350
Discussion in 'The Garage' started by 1979jimmy350, Mar 30, 2004.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    How do you get the plantires off of the out put shaft I am having trouble getting the gear set off of the output shaft
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    there is a small snap ring on the out out shaft. it is very hard to see, but you should be able to feel it with a pick or something.
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    where would a good place be to buy the low/reverse clutch compressor or is it possible to make one
  4. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you can usually get them on ebay for like $40 bucks
    if you need one faster, email me i can get them also
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    would it be easy to make one
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you could but you would need one to copy. they are simple but you need exact measurments
  7. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    do you have one that you could send me the measurments for
  8. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    no i don't i use a universal tool that will do alot more than just the low reverse clutch. sorry /forums/images/graemlins/ignore.gif
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The special tools I used to rebuild mine were some c-clamps and a threaded rod with a piece of steel with a hole in it.
  10. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
