thoes that switched from tbi to 4bbl, i need a hand
Discussion in 'The Garage' started by dodgetruck91, Mar 18, 2004.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    will the fuel pump kik in by it self or how does that get setup? any other pointers are appriciated, thanks
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if you use the stock pump, you will burn it up. the pump stays cool by the fuel running throught it. holley makes somthing to keep the fuel circulating but its like $120
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    what year truck you doing this on ? you should get a pressure regulator and reduce it down to around 7 psi for carb
  4. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    I would get a pressure regulator with the return built in. Kinda pricey though.
  5. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Judging by your username, I'm assuming that you have a 91 Dodge.
    Recently I bought a 1990 Dodge 1 ton for parts. A previous owner had removed the TBI and installed a Carter AFB and Edelbrock intake on it. The stock (in tank) fuel pump was retained, and an aftermarket pressure regulator was plumbed in line. Then right after the regulator, an inline filter like I've never seen was installed. It has one line in... and 2 outs... One out goes to the carb, and the other to the return line. /forums/images/graemlins/crazy.gif
    Seemed to work as the truck runs... but I beleive it's not running right as I'm not sure that the distributor is advancing since it has no vac advance /forums/images/graemlins/confused.gif
    Hope this helps...
    Marv
