Thorleys Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Catman, Mar 18, 2005.
  1. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    :confused: Summit should have my Thorley headers at my door in about a week. I have questions about what others have used in the way of plugs, wires, heat shields, wire seperators......and what problems/solutions you'all came up with. It's a '90 K5 w/350.
    Thanks in advance.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    on my sbc, I used the stock wires and plugs, and no heat shields of any kind. I just zip tied each paid of wire together to keep em off the headers. The plug wires for #1&#3 were together, and 5&7 were, etc. Didnt have a problem.
  3. mrk5
    Apr 20, 2004
    12,343
    1,047
    Northern Colorado
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I like Taylor wires too. I have them on 2 vehicles with headers. They hold up to the heat very well.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Not the cheapest, but I've always liked these wire looms. [​IMG]
  6. dyeager535
    26,980
    You should be able to get to my gallery. Pictures of what I came up with in there.
    multiple pics
    Not sure about older heads but Vortecs have two small drilled/tapped bolt holes where I was able to bolt my wire holders. I either used parts from Oldsmobile 307's (cadillacs used them too) since they had lots of brackets bolted to the valve cover bolts, or I used other things I found that I could drill out to the right size. An hour or so at the wrecking yard and maybe an hour making the brackets work as I wanted.
    I used Accel cut to fit wires, and I'm using stock AC Delco plugs. As you can see, no shields on the plug wires. I had planned on it, but my headers have enough clearance to keep the wires safe.
