Thorwout Bearing Question
Discussion in 'The Garage' started by DuallyK5, May 31, 2006.
  1. DuallyK5
    DuallyK5 Registered Member
    Apr 6, 2006
    32
    New Jersey
    I just got a new cutch kit and it seems that the thrwout bearing has a little side to side wabble like it is not 100% perfect. Is there a problem with that do you think or a little bit of movement wont hurt anything?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    What kind of kit is it? Is it a new or remanufactured kit?
    By side-to-side do you mean the rotating part has some play in relation to the fixed part?
    I know some of the bearings come concentric, and when you spin them they don't look like they are centered, but that is normal and ok. There shouldn't be any play though.
  3. DuallyK5
    Apr 6, 2006
    32
    New Jersey
    yeah
    There is no play it just seems to move side to side but i think if one side stays stantionary that it should be fine. Its a new kit from Perfection Clutch by the makers of zoom. Its like a 250 dollar clutch my budddy had it from not to long ago and he hooked me up
  4. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    my poor poor bearrrrings!..(Mr Scott!!)
    I sold some Borg-Warner throwout bearings they called "Self-Aligning"--the part that touches the pressure plate could be moved from side to side about 1/8" or so either way,it was designed to make up for any misalignment or runout between the clutch and bellhousing..I suppose other manufacturers made them too...you probably have one of theese,judging by the description you gave...
    Remember,its a "thrust" bearing,made to handle heavy pressure under a load while allowing rotation with little friction reistance..once the pressure is applied,it will not wobble around too much..it should have little to no radial play though..:crazy:
