Those Friggin Caddy Eldo calipers!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brian 89KBlazer, May 9, 2001.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I know it was discussed by Shawn a long time ago but I can't remember if was here or on the OR BB. Either way; did/does anyone know how to get the piston on the 78 Caddy Caliper to retract once it's been ratcheted out?? It's not the end of the world for me cause I did it on the old set I have to use for cores while I was stripping them down BUT; it'd sure be nice to know in case I accidentally mess up a new one!![​IMG][​IMG]
    Brian
    89KBlazer
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The easiest way that I've found is to remove the nut that holds the parking brake lever onto the screw mechanism at the backside of the caliper. Then as you press the piston back into the caliper, the screw can spin as it returns to its home position.
    BTW, don't even think about taking the piston itself apart. The mechanism inside the piston has a hefty spring inside, along with some ball bearings that ride on two Torrington style races. Putting it all back together without breaking the races is pretty tricky. Guess how I found out? [​IMG]
    The Cadillac dealers can't get parts for the inside of the piston. They only sell the entire caliper assembly. Luckily I was able to take the measurements of the Torrington races to a shop that specialized in bearings and get the new one that fit. [​IMG]
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    I haven't looked at mine for a couple years, but can't you just screw it back in?
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  4. Brian 89KBlazer
    779
    Ontario, Canada
    Thanks Harry & Pete
    I'll give that a try Harry & unfortunately Pete; mine are in that bad shape that very little "just screw in" on them anymore!![​IMG][​IMG]
    Thanks again
    Brian
    89KBlazer
  5. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    You can literally "screw" the piston back into its bore also. There are some notches in the face of the piston that accept a special spanner tool for doing exactly that. Since I had mine so far apart when I rebuilt them, I used the method I mentioned above. [​IMG]
