Those of you with doublers.... Got a question.
Discussion in 'The Garage' started by Flexy K20, Apr 25, 2003.
  1. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    I am going to be doing a doubler in a few months and I am going to run the Exact 1.5" spacer so I can put the 203 on the back of the 700R4. Will this extra 1.5"'s cause a problem? I will be shortening the wheelbase to about that of a blazers. So basically the question is: those of you with doublers in a blazer would another 1 1/2" cause a problem with the rear driveshaft being to short? I will be putting in one of Jesse's CV shafts. Thanks
    -fLeXy K20
  2. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    The first Gen Doubler was the longest of all because it used roughly a 3" aluminum spacer, plus a factory adaptor which was about 6". Meaning, the Gen one doubler was 6" longer than their current configuration. I know of several K5 owners who use these with 6" and above lifts and have no problems with driveline issues.
    I clocked my NP205 up to flat - meaning my inputs and outputs are all level. Mine is behind a TH350 and the driveshaft lengths are 35.75" front and 36" rear.
    I don't think you will have problems with driveline if that answers your question. /forums/images/graemlins/thumb.gif
    I'll tell you one thing - I love having 4:1. I might regear to 5.13 someday.
  3. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    I don't think that would be a problem.
    Ideally, you could "adjust" your WB (if your redoing it anyway) so that you can have the same length drive shaft front and rear (buy 3 at once, two for the rig, one trail spare).
    that is the ultimate goal IMHO
  4. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    Yeah that would be the bast way of doing it, but wouldn't that ammount to the rear axle being pretty damn far forward? Meaing a really short wheelbase? Later
    -fLeXy K20
  5. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Not hard w/ the doubler. Keith is off by about an inch (close enough make it up in the splines) his wb is around 109-I think
