Those running holley truck avenger
Discussion in 'The Garage' started by Muddytazz, Nov 2, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Where are you running your vacuum line for the brake booster too?
  2. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    intake port
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    On my current quad, the brake vacuum is hooked to the base of the carb and my heater controls and tranny modulator is hooked to the intake port. With my new motor I'm running an edelbrock air gap intake and the holley truck avenger. Ports are different?
  4. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,608
    602
    Hooper, Utah 84315
    You should run the Brake booster off the bottom of the carb for vac. Not sure if it makes a difference but in my head it does cause from the carb you get eight times the vac that you get from one intake port.
  5. ntx78k5
    ntx78k5 1/2 ton status
    Oct 22, 2004
    166
    Home of the Rangers
    What he said :waytogo:
  6. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    What vacuum line? (hydroboost for me)
    I did notice that both the large vacuum ports are on the passenger side. Figured that kinda sucked for vac boost.
    I just got a brand new Truck Avenger from Holley, and there are 2 large vacuum ports, one at the rear of the carb and other at the front. Like I said both are on the passenger side. If it were me I would use that rear one.
    I did have a port on the intake (regular RPM), but it wouldn't clear the fuel bowl.
    Do you need pics?
  7. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    Mine has a large vacuum port on the pass. side of the carb just for the brake booster. Check the owner's manual for location if you do not see it.
  8. TWISTEDJACK
    Jul 24, 2002
    882
    Boise, ID
    I checked mine at lunch and I was wrong the booster is off the base of the carb and the tranny is off the intake port :doah:
  9. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    left rear bottom of the cholley truck avenger. it says somewhere right in the directions i think. i remember i found it somwehere when i hooked mine up
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah I found the book that came with it AFTER I called holley(which is a second story). Brake booster in back, PCV in front, top front is vac advance....the only other port on the carb is the little one next to the PCV port in the front. Have no idea if I even need that.
    On the other story, I called Holley tech support to ask them about the brake booster hook up, they asked name and number of carb, told them that info and they flat out told me to send it back to them and they'll send me a new carb. It's the 1st design (#90670) the second design is -1 and the 3rd design is -2 :D
  11. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Didn't you just get it? Where'd you scrounge up an old one? I'm getting mine swapped out this week too, but I've had it since '02. :rolleyes: Lot's of fighting, and I didn't know why.
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Nope, I got mine on a motor I bought from a fellow ck5er.
  13. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    It's a good deal. I sent mine in on a Tuesday and had the new by Wednesday the following week. That was a couple of weeks ago.
    I haven't drove it on the street yet, but I did some driveway tuning and it seems better than the other one I had. There are some obvious visual differences on the metering blocks. I pulled mine apart to re-jet.
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Well I'm pulling the old motor out and putting in the new motor on saturday, so I guess I'll just have to wait a bit before I can fire it up.
  15. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Are there recalls on the 770 model too, or justthe 670????
    My 770 doesn't have any of the '-' in the part no....
  16. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Don't know, you'd have to contact holley. If you have a problem with a stumble/stutter/hesitation then you should contact them. If not, don't worry about it. IIRC, the 670 came out before the 770 and the 470, so maybe they had all the bugs worked out already when they made the other two.
