Those Who Have Done Hydro 465 Swap ?
Discussion in 'The Garage' started by az ranger, Apr 9, 2005.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    Can I Use Still Use My Auto Steering Column And Just Keep It Park Or Nutrual So The Nutrual Safty Swith Will Work And Put In Reverse For Back Up Lights At Least Temporally Untill I Can Change Over To Manual Column.
    Also
    Do I Have To Take Whole Pedal Assembly From Donor Truck Or Can I Just Add Clutch And Brake Pedal To Existing Pedal Assembly.
    Its An 88 Jimmy And Will Be Full Hydro Clutch
    Donor Truck Is 87 2wd I Ton
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    you can just take the cluch brackit off, like in the tech write up here
    a member was doing the swap and ran into problems with the brake plunger not lining with the doner brake pedel, so you might want to check.
    and i think you could eather jump the nutral safty wires or wire it to the cluch switch.
  3. dyeager535
    26,978
    I jumped the neutral start/clutch lockout switch, it pays to be able to move the truck via the starter, believe me. :)
    IIRC, the auto trans or manual uses similar backup wiring, and you can just disconnect the wiring connectors and add/run the right end to the manual trans. I don't recall having to cut/splice any wires to run the reverse lights, but also not really sure if my harness was manual or auto trans originally.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    its way easier to remove and install a full hydro clutch pedal setup than it would be to just remove the clutch pedal bracket. i didnt have any problems lining mine up on my truck, or Tim's when i installed the pedals.
  5. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    I took the whole pedal bracket (brake and clutch) out of the donor truck. I wanted the small brake pedal but it was a trick trying to get that plate behind the steering column if you dont remove the column.
  6. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah i wouldent have said it, except for the fact a member doing the swap said it wouldn't line up.
    check first if not you gotta cut..
  7. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    Your one of tims buddies?
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    his problem was he had the mastercylinder way to high.
    you can leave the auto column, the nuetral safety switch needs to be plugged in. for the reverse lights, there is a wire that the plug from the switch on the column plugs into that runs threw the firewall and down to the tranny. this is a factory part.
    when i did my swap i put in a manual column, instead of trying to rewire/jump/splice for the nuetral safety switch, i plugged it in, making sure its in park and zip tied it way up under the dash out of sight. its been working great for 2 months.
  9. RSNHELL
    RSNHELL Registered Member
    Jan 17, 2005
    53
    SANTA ROSA,CA
    I kept my auto column just the way it was.I just took the shifter off and keep it in park to start it,and put it in drive when I park it (just in case I get a stupid thief, hee.. hee..)
  10. az ranger
    May 9, 2004
    139
    Safford AZ
    will I be able to bolt the pedal assembly up with out dropping down the steering column. eventually I plan to swap the manual column but I have been working on this swap for way too long and I just want to get it rolling again before its to hot to drive it thanks
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you need to pull the 2 nuts that hold the column to the dash, the pedal brackets bolts there also. but you should be able to get it in over the column with out completely removing it.
  12. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Well you can do it with the column up in place but just watch all the hanging or wires in the area and ...If I did it again I would STILL drop the column , much easier in the long run...(or it will take the better part of your sanity and temper to get it in without dropping the column..) Jm2c :D
    Went from this ..
    To this..I only had to cut one wire the rest just unplugged.
  13. az ranger
    May 9, 2004
    139
    Safford AZ
    It did take the better part of my sanity and I learned some new cuss words and that was just taking the original brake pedal assembly out. I didnt have time today to put new assebly in. it looks like I will have to take the pedals off and put them back on when I get the assembly in place. and I do have the column drooped.
    what about the clutch support rod is it a must have. I cant remember were it bolted to the donor truck.
  14. k5blazin
    k5blazin 1/2 ton status
    Dec 19, 2004
    262
    Elizabethtown, PA
    I think the clutch support rods hold the studs that the clutch master cylinder bolts on to. so yes, you have to keep them.
  15. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes keep those rods, if you don't the master cylinder may bend the firewall, depends on how much force is on it.
    your 88 should have dimples on the firewall to the upper left hand corner of the fuse box on the engine side of the firewall. if not, i have measurments on where they are located, just let me know and i will find and post them.
  16. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    yup sure does. Only way I was able to drive over 1,000 mile home when my slave cylinder's rod snapped so I no longer had a clutch!
  17. k5blazin
    Dec 19, 2004
    262
    Elizabethtown, PA
    Would a 84 have the same dimples for the master cylinder?? i am also doing a hydro 465 swap and was wondering about that.
  18. k5blazin
    Dec 19, 2004
    262
    Elizabethtown, PA
    :shocked: wow
  19. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    85 was the first year for the factory hydro clutch, so i don't think it will have the dimples.
  20. az ranger
    May 9, 2004
    139
    Safford AZ
    the dimples are there for mine although I am confused becuase there are four dimples in that location I thought there would only be two for the master cylindar bolt holes.
