Those who have moved there batteries...??
Discussion in 'The Garage' started by stallion85, Mar 15, 2006.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I removed my front inner fenders for my narrowing project. I am removing the HVAC system so I can have the space there on the firewall.
    Now has anyone used there factory battery tray mounted to the firewall?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    No but I just moved mine behind the passenger seat for better weight distribution.
    Just went to the parts store and bought a $10 plastic battery box then just got some 2/0 guage wire.
  3. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    x2 :thumb:
  4. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I mounted the aux battery in the rear of the '73's bed in a Summit aluminum battery box, with 0/1 gauge cable to the engine compartment.
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    well I have 2 1200ca batteries.. HUGE.. 19Lx12Wx9H EACH!!!! from a ford lm-8000 dumptruck... I am going to mount them in my bed... used a street sign for the mount... my father works for a local borough and they had metal scrap day.. so I just went back there and grabbed one as he said they just trash it.... so a little sittin there with a few beers trying to figure out how to make a bracket and I did it....
    lemme find some pics....
    so I still have to buy threaded rod... go through the bottom hole.. double nut... then put a nut on top.. then I can lay the top bracket on and nut it down.... all in all I think it was a good idea..... welded it up pretty good with my bird crap welds :haha:
    that is 1 sign post..... also those batteries... each one is like 2 normal batteries... im going to mount this in my bed... run the winch to it..... run an isolator so that way if I die in a mud hole and cant get started.. hopefully I can pull myself all the way out!!! HOPEFULLY!!!!!
  6. RootBreaker
    Nov 29, 2001
    5,117
    173
    oh yeah I couldnt find much about these batteries.. only that they are big and were free... new too!!! :bow:
    each one is 1200ca and 395 reserve minutes each... that is all I could find out
    each of my dual duralast golds are 1000ca 195 reserve minutes each... so these 2 have just over the reserve minutes of 1 of those!!!! :wink1:
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    What are you wanting to know?
  9. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    If anyone used there stock battery tray mounted to the firewall. I was looking at it today when I took all the heater and A/C stuff out and it looks like it will work......
  10. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Jeff, I've seen this on here, w/ a red and a yellow top, somehow methinks KidJethro's buggy?
  11. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    I did something similar to this with 2 semi batteries. Builts an angle iron frame they sit in and a piece or strap across the top to hold them down.
  12. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Sure did. I made some custom triangle supports to the firewall up to the battery tray. I also strengthened the firewall sheetmetal using a large piece of 1/8 plate. On a side note DO NOT rely solely on the little factory hold down clamp to keep the battery in the tray. On a roll over it will come out, ask me how I know.
    Here's a pic, you might have to modify the brightness to see it. If you need a better pic let me know.
    BTW , Rob also has this setup, only with dual batteries.
