Those who have shaved 14ff??
Discussion in 'The Garage' started by stallion85, Aug 29, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    What type of blade did you use on your sawzall. I have gone through two De Walt metal cutting blades and have only cur about 2". Is it this big of a pain in the ass or do I have the wrong blades?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I used a cut off wheel on my grinder /forums/images/graemlins/dunno.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I used cutoff wheels on the angle grinder (like 5) to cut my 14bff up. I didn't have a sawzall though at the time. The best blades I have found for a sawzall are Millwakee "Torch" blades They are much heavier duty then standard blades and cut well.
    Harley
  4. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I think I used a 14tpi. I do remember it only took about a minute to cut right through. Was like cutting through butter.
  5. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    i used a single sawzall blade from home depot, I forget who makes them but they are called "the torch". Works really well. I cut off one big hunk, then angle-grinder'd it all smooth.
    j
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Took me 2 blades. I also used the torch.
    Is your saw only 1 speed? I wiped out the first blade because I ran mine at full power (mine is a 11.5A motor which is more powerfull then most).
  7. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    yep same here... bought a 12 pack of 6" sawzall blades for $22 (actually they where an xmas present). 14tpi, not quite like butter but about 2minutes on each cut and I knocked off twoo large hunks, then I went through 3 4.5" grinding disks /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif
    Then smoothed it out with a flap wheel
    [​IMG] /forums/images/graemlins/grin.gif
  8. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    3 words: Portable Band Saw
    It took less than a minute with the saw and 20 minutes with teh grinder /forums/images/graemlins/thumb.gif
  9. tRustyK5
    Jul 23, 2000
    36,167
    1,365
    E-town baby!
    One 5" cut-off disc (3/32" thick), half of a regular grinding disc and then a flap wheel disc to blend. Grand total was about 10 minutes. /forums/images/graemlins/dunno.gif
    Rene
  10. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    I have a question. Anyone ever hit the bottom bolt hole while doing this? I am going to get to shaving mine as soon as I finish wrestling thos van spring perches off of the axle tube /forums/images/graemlins/angryfire.gif Wish I could find a set of those to put on for the Jimmy. Those things are nothing but beef and a PITA to cut/grind off.
  11. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I got a little happy with my grinding and I got pretty close, I had to round off the bottom of the bolt that holds the cover on. /forums/images/graemlins/thumb.gif
  12. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    Sounds like this is the blade to go with. Should have asked first /forums/images/graemlins/whistling.gif
  13. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Yes, I shaved mine until I started seeing threads on the bottom bolt. I didn't mean to go this far but sh*t happens. I bought the DIY4x 14bff cover kit and used the 5/16" ring to beef the lip at the bottom. I had problems with the cover peeling back so I sandwiched the cover with that plate.
    Harley
