Those who have swapped 700r4 for 350 ... linkage ???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K1Orion, Mar 4, 2003.
  1. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I am swapping a 700r4 in place of the factory th350. I am wondering how others who have done this swap hooked up their sgift linkage. Are you able to shift to all gears? I know I can hook up the factory linkage, but won't the steering column affect the ability to shift to all gears? /forums/images/graemlins/confused.gif
  2. Mr GearHead
    Mr GearHead Registered Member
    Jan 3, 2002
    10
    Atlanta, GA
    I have a '77 that I put a 700r4 in and just used the stock linkage. There was enough travel in the colum to reach all the gears but frist was close. I had a frend with a '78 K1500 that did the same thing and he had no problems. He also went to the dealer and bought a gear indicator from a newer model and put it in his gague cluster so he has the D with the little circle around it.
  3. 85army tank
    85army tank 1/2 ton status
    Sep 25, 2002
    276
    southren mn
    /forums/images/graemlins/k5.gifi swaped from a 700 to a 350 and just used the stock linkage i think i might have used the lever from the 700 but i cant remember i hope this helps /forums/images/graemlins/k5.gif
  4. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    If it dosen't work right, just hook up some kind of a floor shifter.
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    When you unhook the linkage off the tranny, you'll notice the column shifter is now loose throught the whole range...
    The detents or "clicks" are in the tranny not in the column shifter...
    The only problem you should have is the needle won't line up right where it says P-R-N-3-2-1 or whatever.
  6. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i cant get first...art carr should help! /forums/images/graemlins/thumb.gif
