those who run 17's
Discussion in 'The Garage' started by 88-3/4t-bad boy, Sep 20, 2006.
  1. 88-3/4t-bad boy
    88-3/4t-bad boy 1/2 ton status
    Nov 27, 2005
    150
    Texas
    i want to order some dc-1's from 4 wheel parts. they are 17x9 rims. can you put tires on it if they are meant for 10" wide rims? how hard would it be? i would go with some welds but they are just to damn expensive. any advice would be great. if not i guess i could just go with 16x10's
  2. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    yes, you can put tires recommened for a 10" wide rim on a 9" wide rim very easily.
  3. 88-3/4t-bad boy
    Nov 27, 2005
    150
    Texas
    ok sweet. just curious. i like to have room for improvement. if'n you know what i mean. thanks
  4. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    x2 Ive had tires recommended for 10" rims on a 6.75" rim with no problem, 9" should be fine.
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    that's the exact setup I'm running now.. my 33x12.50's are recommended for a 10" wide rim. I have a 6.75" wide rim.. but all that's about to change cause I got some beadlocks and am getting some wagon wheels :D
    But yeah, there are people running 44's on 8" wide wheels.
  6. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    Just check your tread wear. Going on a narrower rim can cause the tire to ballon or be rounded wear the tread meats road. You may have to play with air pressures to get the largest contact patch. From what Ive seen I wouldnt recomend putting a 12.5 wide tire on anything smaller than a 8" rim. So just stay under 14" wide on the 9" rims and you should be ok.
