Those will single exhaust post up
Discussion in 'The Garage' started by sandawgk5, Jan 19, 2007.
  1. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am looking at how those with single exhaust have it run. I need to run a cat also I will be running 3" from the y-pipe out the back and I am looking for a side exit behind the rear tire. I run a flip so the stock exit wont work.
    It looks like I have room to fit the tail pipe between the frame and the rear leaf and run it up by the floor underneath the wheel well. The object is to get it as high as possible and out of the rocks but clear of all the moving suspension parts and stuff.
    Any input and pics would be great.
    Ira
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    I run a custom 2.5" Y-pipe into a 3" high-flow cat into a Flowmaster Super 40 (3" inlet, dual 2.5" outlet) dumping just over the axle. Here are the pictures of it:
  3. sandawgk5
    Oct 28, 2003
    6,881
    Do they say anything at the smog station aboot dumping it under the truck? I would prefer to get it out from under the rig as down here most of where we run is dry and dusty.
    Ira
  4. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    I'm stuck in Smog-Nazi Cali as well, and when I took it to get smogged, they didn't really bother me about it. I dumped it because I plan to do a shackle flip on the rear to get rid of the shackle, and there's not enough room there to run pipes out.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Stock location works for me with a shackle flip , pipe above spring saves the exhaust on the rocks :thumb:
    I also have a exhaust shop made y-pipe , single to a bigger cat I installed , to a single muffler up close to the floor in front of the axle .
  6. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Look at my link, the last pic will show the exhaust reroute for the Flip and Inboarded Shocks.
    Basically, after the Y, it goes into the Cat then into a Flow-50 then bends and routes on the outside of the frame rail. Very similar as this one
    http://coloradok5.com/ranchoshockreview/rearshocksonramp.jpg
  7. sandawgk5
    Oct 28, 2003
    6,881
    This is what I am looking at doing but I am not inboarded yet so room might be tight
    Ira
  8. sandawgk5
    Oct 28, 2003
    6,881
    Holy big pic batman:D
    Ira
  9. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ira, im not sure if i like that setup or not. wheres the end of it? does it just point down? it just looks funny to me, but it does get it up and out of the way.
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yep, I've got a 3" pipe from the Y on my '91. It's on the stock hangers to the axle. Slight upward kink at the axle (flip + 1 1/2" zeros) then continues straight backwards with only a slight kink in it running between the shackle and gas tank, straight out the back just below the bumper.
    Sorry but I can't get a pic now and I'm going away tomorrow.
  11. sandawgk5
    Oct 28, 2003
    6,881
    Mine will bend at the rear and out the side right under the rear quarter.
    Ira
  12. sandawgk5
    Oct 28, 2003
    6,881
    Here is a crude paint version of what I intend to do. It will all be mandrel bent 3" aluminized.
    Ira
  13. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    3" Flowmaster Cat back on my '91 'Burb
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    see now i kinda like that, eventhough i didnt really like the last one:haha:
    any particluar reason you dont just want to run the stock piping? i got all the factory tubing for my '88 from the y pipe back and it was all 3". then i just cut the end part off. got all the tubing which was pre-bent and everything for under $80.
  15. sandawgk5
    Oct 28, 2003
    6,881
    Ya you can see my stock tailpipe dumping by the gas tank. It is not 3" it looks aboot 2.5 and aboot the only good portion of the exhaust is the y and the tailpipe the rest looks like swiss cheese:doah:. The muffler is attached to the cat by about 1 square inch of metal and non of it is mandrel bent it is all that kink bent ****:o. I am putting a new cat and a Flowmaster super 40 in so I figured I would change everything out to 3" mandrel bent. When I get the cash I will prolly go with a set of TES headers. I dont run inners so plug changes are not a big deal to me. I have to get the new exhaust on by mid march as I have to smog for my registration and I do not think it will pass the way it is.
    Ira
  16. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Here are a couple pics of mine...If you want more detail and info, just let me know.
  17. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I have a single 3" that dumps right next to the gas tank armor. No way it will hang up on anything. I run a Flowmaster 50 SUV, and it is pretty loud inside the truck. I donno if it's the muffler, or where the exhaust is dumped, but the whole exhaust system is tucked way out of the way, so I'll deal with it for now.
  18. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I will see about getting you a pic of my exhaust when i get home tonight. Here are a few pics of my exhaust.
  19. Slapperbar
    Nov 29, 2005
    2,747
    3
    Mine's a Big Block 70 series, Quiet inside and nice tone outside.
  20. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    Yeah, I'm not gonna lie, the Super 40 is VERY loud. I have to drop down to an idle when driving past the fuzz, because the last thing I want happening is them pulling me over for a loud exhaust, then writing me up for no mud flaps while they're at it. That would ruin my day...
