Those with 38"+ tires and non-OD trannies...
Discussion in 'The Garage' started by heavy4x4, Apr 7, 2004.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Those with 38\"+ tires and non-OD trannies...
    1) What the heck gear ratio are you guys running. I never really punched in the numbers until a day or two ago, and with a non-OD tranny (1.00 final gear) and 39.5" tires, the engine will be turning about 2200 rpm at 70 mph (which sounds ideal to me) with 3.73's for a gear ratio!
    2) Here's the reason I'm asking...I'm trying to figure out what tranny and gear ratio I want to use with 39.5's
    These are the choices I'm thinking: (the truck will be mainly off-road, but some road use including freeway)
    TH700R4 - 5.13 (good, but not sure about the strength of the tranny with the larger tires)
    NVG4500 - 5.13 (probably one of my best options)
    SM465 - 3.73 (should still have decent crawl/low gear and be able to travel on the freeway - and I wouldn't have to change my gear ratios /forums/images/graemlins/woot.gif - but I would be going D60)
    TH350/400 - no idea (thinking 3.73's for freeway driving, but then the low gear is gonna be really lacking)
    What would you do? /forums/images/graemlins/ears.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Those with 38\"+ tires and non-OD trannies...
    I am running 4.10 and I'm perfectly happy with the way it cruises.
    4.56 or 4.88 would still be ok for highway cruising, 5.13 would be pushing it.
    3.73 would make for a gutless truck that had to use granny gear to take off most likely.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i have the sm465np205 4:10 39.5 combo and i really wish i had 4:88's-5:13's
  4. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    I have 4.10's with 42" TSL's. It also does have a 472cid, so its not exactly a smallblock.
    I took advantage of dual cases to offset the gear ratio. I think thats pretty much mandatory if you want a decent crawl ratio and still be geared for highway use.
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Damn, I'm lucky if I can hit 70 at all /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    38.5/14.5 SX, TH350, 4.10
  6. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    sm 465 4.88s 39"s
    2700-3000rpm and still the slowest thing on the hiways
    tall gears and a reduction box is the way to go
  7. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Damn, I was thinking of going 4.10 to go with my new 35", but that sounds like I will be geared too low for my DD. I'm gonna be taking a trip up to central Oregon this summer, so the ability to cruise 70-80 at decent rpms is important. [darn], I may have to go 3.73 or think of stepping up to 37" tires. It would be a no brainer if there wasn't such a price jump from 35" to 37".
    Sorry for the hijack.
  8. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    5.13's and 38's is what you need to run with a TH350/400. That puts your gear/rpm ratio back to what the truck was stock. DO NOT I REPEAT DO NOT RUN 38's and 3.73's! You'll burn up your auto tranny real quick...ask me how I know /forums/images/graemlins/whistling.gif I will be running 5.13's very soon. /forums/images/graemlins/waytogo.gif They ARE NOT too much for the freeway. In fact, they should put your rpms back into the "peak power" range for the freeway. You rig should run better and get MUCH better milage than if you went with 3.73's. Do some research on your own. There are many opinions floating around out there and not all of them are correct.
  9. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    I agree with shane
  10. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    i run 4.10's and 38. Would be nice if i had 4.56's. Current set up does seem to put some stress on engine and trani when driving 60+.
  11. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Nope, you'll still be geared too tall. Go with 4.56's for 35's.
    Here is a bit of a comparison for you all using 3.73 gears. They are from trips I took over the last couple years in my /forums/images/graemlins/k5.gif
    Trip 1 - Vancouver,WA to Bakersfield, CA pulling 19' camp trailer
    3.73's and 33x12.50's
    Mileage = 15-16 mpg
    Trip 2 - Vancouver, WA to West Glacier, Montana again pulling 19' camp trailer
    3.73's and 35x12.50's
    Mileage = 12-14 mpg
    Trip 3 - Vancouver, WA to Libby, Montana Pulling NOTHING
    3.73's and 38x12.50's
    Mileage = SUCKED ASS!!! 9-10 mpg /forums/images/graemlins/eek.gif /forums/images/graemlins/angryfire.gif
    Stay with the 4.56's dood.
  12. Bhintz
    Mar 28, 2003
    1,341
    Roswell, Ga
    Mileage = 15-16 mpg
    Mileage = 12-14 mpg
    [/ QUOTE ]like I said I agree with you but the drag issue is going to kill MPG
  13. GMC
    GMC 1/2 ton status
    Jun 18, 2002
    108
    Lacey, WA
    I have 4.88's in a D60/70 setup running 38" Boggers with a healthy 350 and a T-350. Since 39.5's are quite a bit bigger than 38's and running 1 ton axles and other heavier equipment on a vehicle I would for sure go with 5.13's all the way. You could still go on the freeway with that set-up as I do with mine.
  14. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Shane, What RPMs are you running at say 65-70 MPH, just curious...
  15. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Hijack
    /forums/images/graemlins/eek.gif I'm from Libby, MT thats not a town I ever expected to be mentioned on here /forums/images/graemlins/waytogo.gif
    end hijack
  16. heavy4x4
    Aug 28, 2002
    3,270
    Thanks for the ideas, all, but geez...sounds like you guys have no problem with running an engine at 3,050 rpm on the freeway (1.0 tranny gear, 5.13 axles, 39.5" tires).
    Personally, I'm not comfortable doing that, I'd rather be below 2500. (With 4.10's I'd be at 2400)
    Looks like right now I should be thinking about the 700R4-5.13 or NV4500-5.13 setup.
  17. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Right now I turn about 2200. When I get my 5.13's in it'll jump to about 2800.
  18. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Right now I'm running 4.10's and 33's /forums/images/graemlins/thinking.gif /forums/images/graemlins/doah.gif
  19. Ryan B.
    Jul 18, 2001
    5,693
    CA
    TH350, 4.56's and 38's i spin 2800 at 65 on the freeway.
    I switched to 35's for the street and now i'm at 3000 at 65, 3200 at 70. /forums/images/graemlins/dunno.gif /forums/images/graemlins/doah.gif
  20. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    You'll be turning 3350 rpm at 70 with 5.13's and 38's...
    I run 4.56's with 39.5's an SM465 and a 6.2 diesel. 2550 rpm at 65 mph...at 70 the tires start to shake so I just don't go there LOL. The combo I have would be perfect if I had another gear after 4th, around town it's perfect. With an auto tranny I'd have to say deeper would be better though. A manual tranny rig seems to tolerate slightly taller gearing better than the auto rigs do.
    Rene
